Introducción
Use this guide to remove or replace the front camera and the sensor cable in an iPhone SE 2022. This assembly includes a microphone, the front camera, a proximity sensor, and an ambient light sensor.
This guide was performed on the A2783 (international) model.
If you do not replace the adhesive seals when reassembling, your device will function normally, but will most likely lose its water protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Qué necesitas
Power off your phone before beginning disassembly.
Remove the two 3.4 mm P2 pentalobe screws on the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen's plastic bezel, not the screen itself.
Skip the next two steps.
Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the lower half of the front panel, as close to the home button as possible.
Lift the front panel with the suction handle to create a small gap between the front panel and the frame.
Insert an opening pick into the gap under the screen's plastic bezel.
Slide the opening pick to the bottom right corner to slice the front panel adhesive.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Slide the bottom left opening pick along the left edge of your phone to slice the adhesive.
Stop near the top left corner of the display.
Remove the opening picks.
Gently pull up on the suction handle to lift up the bottom edge of the display.
Remove the suction handle.
Slide an opening pick underneath the top left corner of the display.
Slide the opening pick around the top left corner and along the top edge of the phone to slice the remaining adhesive.
Slide the display assembly slightly down in direction of the charging port to disengage the clips holding it to the rear case.
Open the phone by swinging the display up from the left side, like the back cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Remove the four Phillips screws securing the lower display cable bracket:
Two 1.2 mm-long screws
Two 2.8 mm-long screws
Use a pair of tweezers to carefully remove the lower display cable bracket.
Use the pointed end of a spudger to disconnect the battery by prying the connector straight up from its socket.
Use the pointed end of a spudger to disconnect the bottom two display cables by prying the connectors straight up from their sockets.
Use a Phillips screwdriver to remove the three 1.2 mm-long screws securing the front sensor assembly bracket.
Use a pair of tweezers to carefully remove the front sensor assembly bracket.
Use the pointed end of a spudger to disconnect the front sensor assembly by prying the connector straight up from its socket.
Unfasten the three screws securing the earpiece speaker bracket:
Two 2.6 mm-long Phillips screws
One 1.6 mm-long Phillips screw
Use a pair of tweezers to carefully remove the earpiece speaker bracket.
Use a pair of tweezers to lift the front facing camera out of its socket and swing it to the left to get free access to the earpiece speaker.
Unfasten the two screws securing the earpiece speaker:
One 1.8 mm-long Phillips screw
One 2.3 mm-long Phillips screw
Apply a heated iOpener to the top edge of the screen to loosen the adhesive securing the front camera and sensor assembly. Apply the iOpener for at least 2 minutes.
Use the pointed end of a spudger to carefully pry the proximity sensor out of its recess on the front panel.
Use the pointed of a spudger to carefully pry the ambient light sensor out of its recess on the front panel.
Slide an opening pick underneath the front camera and sensor cable assembly to separate it from the front panel.
Use a pair of tweezers to remove the front camera and sensor assembly cable.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
3 personas más completaron esta guía.
