Introducción
Couldn't find a guide to fix a customer’s iPad so here it is put a lot of work into providing something you can use as a reference! Thanks, comment please!
Herramientas
No se especificaron herramientas.
Partes
Be sure to turn off the iPad by pressing and releasing the volume up button then volume down.
Press and hold the side button until the screen turns off.
Use the slider if you can.
25 personas más completaron esta guía.
21 comentarios
My Face ID no longer works?
Most likely you may have damaged the flex of proximity sensor.
Check connector
Check placement with flash light make sure everything is aligned correctly
why not get a new flex cable from ebay or aliexpress
imab -
