Saltar al contenido principal
iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement
Qué necesitas
    • Before starting repairs, take your iPad off the charger and power it down.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear eye protection. The glass may break, sending pieces flying.
  1. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Adhesive tip: paso 2, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Adhesive tip: paso 2, imagen 2 de 2
    • Removing the screen involves using an opening pick and/or halberd spudger to separate the adhesive securing the screen to the frame.
    • As you slice through the adhesive, note the following:
    • The adhesive on the long edges of the iPad is about 4 mm wide. Avoid slicing deeper than that, or you risk damaging the display panel.
    • The adhesive on the short edges of the iPad is about 2 mm wide. Avoid slicing deeper than that.
    • Take especially care when slicing near the home button and charging port to avoid damaging the flex cables.
    • Take extra care when you slice near the front facing camera, to avoid damaging or smearing it.
  2. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Heat the left edge: paso 3, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Heat the left edge: paso 3, imagen 2 de 2
    • Apply a heated iOpener to the left edge of the screen to loosen the adhesive underneath. Apply the iOpener for at least 5 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    • The display adhesive of the iPad is strong and the glass breaks easily. You need to reheat and reapply the iOpener in each section several times during the display removal.
  3. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Anti-Clamp instructions: paso 4, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Anti-Clamp instructions: paso 4, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Anti-Clamp instructions: paso 4, imagen 3 de 3
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Elevate the iPad enough for the Anti-Clamp's arms to rest above and below the screen.
    • Position the suction cups near the left edge of the iPad—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  4. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement: paso 5, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement: paso 5, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement: paso 5, imagen 3 de 3
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  5. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Apply a suction handle: paso 6, imagen 1 de 1
    • Once the screen is warm to touch, apply a suction handle to the left edge of the iPad's screen, above the Smart Connector port and as close to the edge as possible.
  6. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert an opening pick: paso 7, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert an opening pick: paso 7, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert an opening pick: paso 7, imagen 3 de 3
    • While holding down the corners of the iPad, repeatedly pull up on the screen, then ease it back down to weaken the adhesive. This will eventually create a small gap in the seam.
    • If the edge cools down during the pulling process, reheat the edge with an iOpener before proceeding.
    • Once you've created a small gap, insert the tip of an opening pick into the gap.
    • Don't insert your opening pick deeper than 3–4 mm, or you risk permanently damaging the display panel.
  7. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 8, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 8, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 8, imagen 3 de 3
    • Reapply the iOpener to the bottom left corner of the iPad for at least 2 minutes, spanning from the opening pick to the home button.
    • After letting the adhesive soften, insert an opening pick or halberd spudger into the gap next to the opening pick.
    • Don't insert your slicing tool deeper than 3–4 mm, or you risk permanently damaging the display panel.
    • Use an opening pick or halberd spudger to slice the adhesive along the bottom left side of the iPad. If the slicing becomes difficult, reheat the edge and try again.
  8. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert an opening pick: paso 9, imagen 1 de 1
    • Insert an opening pick underneath the bottom left corner of the screen to prevent the adhesive from resealing.
  9. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 10, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 10, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 10, imagen 3 de 3
    • Reapply the iOpener to the upper left corner of the iPad for at least 2 minutes, spanning from the opening pick to the front facing camera.
    • Use an opening pick or halberd spudger and slide along the upper left edge of the iPad to slice the adhesive.
    • If the slicing becomes difficult, reheat the edge and try again.
  10. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert an opening pick: paso 11, imagen 1 de 1
    • Insert an opening pick underneath the top left corner of the screen to prevent the adhesive from resealing.
  11. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 12, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 12, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 12, imagen 3 de 3
    • Reheat your iOpener and apply it the top edge of the device for at least 2 minutes.
    • Use an opening pick or halberd spudger and slide along the top edge of the iPad to slice the adhesive. Stop before you reach the front-facing camera.
    • Don't insert your slicing tool deeper than 2 mm, or you risk permanently damaging the display panel.
  12. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert an opening pick: paso 13, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert an opening pick: paso 13, imagen 2 de 2
    • Insert an opening pick underneath the screen just before the front-facing camera to prevent the adhesive from resealing.
  13. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 14, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 14, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 14, imagen 3 de 3
    • Reheat your iOpener and apply it to the top edge of the device for at least 2 minutes.
    • Insert an opening pick or a halberd spudger just past the front-facing camera.
    • Use your cutting tool to slice the remaining adhesive underneath the top edge of your device.
    • If the slicing becomes hard, reheat the edge and try again.
  14. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert an opening pick: paso 15, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert an opening pick: paso 15, imagen 2 de 2
    • Insert an opening pick underneath the upper right corner of the screen to prevent the adhesive from resealing.
  15. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 16, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 16, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 16, imagen 3 de 3
    • Apply a heated iOpener to the right edge of the screen for 5 minutes to loosen the adhesive underneath.
    • Use an opening pick or halberd spudger and slide along the right edge of the iPad to slice the adhesive.
    • Insert an opening pick underneath the center of the right edge to prevent the adhesive from resealing.
  16. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert an opening pick: paso 17, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert an opening pick: paso 17, imagen 2 de 2
    • Insert an opening pick underneath the bottom right corner of the iPad to prevent the adhesive from resealing.
  17. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 18, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 18, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 18, imagen 3 de 3
    • Reheat your iOpener and apply it to the bottom edge of the device for at least 2 minutes.
    • Insert an opening pick or a halberd spudger underneath the bottom right corner of the iPad.
    • Slide the opening pick along the bottom edge of the iPad, stopping short about 12 mm before reaching the home button.
  18. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert an opening pick: paso 19, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert an opening pick: paso 19, imagen 2 de 2
    • Insert an opening pick underneath the screen just before the home button to prevent the adhesive from resealing.
    • Use the tip of an opening pick or an halberd spudger to slice the adhesive beneath the home button.
    • Don't insert your slicing tool deeper than 2 mm, or you risk permanently damaging the home button.
  19. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 20, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Slice the adhesive: paso 20, imagen 2 de 2
    • Insert an opening pick or a halberd spudger just past the home button.
    • Use your cutting tool to slice the remaining adhesive underneath the bottom edge of your device.
  20. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Loosen and slice any remaining adhesive: paso 21, imagen 1 de 1
    • At this point, you've sliced through most of the screen adhesive. Use an opening pick to carefully slice any remaining adhesive along the edges until the screen is freed.
    • If some parts are stubborn, heat the area with an iOpener to loosen the adhesive.
  21. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Lift the display: paso 22, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Lift the display: paso 22, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Lift the display: paso 22, imagen 3 de 3
    • The iPad shown in the following two steps is the iPad Pro 12.9" 1st Generation. The internals look slightly different but the taping procedure is the same.
    • The display cables in this iPad are very short. Read the next two steps before you proceed.
    • Do not pivot the screen about the lower edge. The display cables don't have enough slack to allow for this and will tear if you do not slide the screen towards the front-facing camera as you lift.
    • The display cables will tear if you raise the screen more than 90º.
    • Lift up the upper edge of the screen and slide the entire screen towards the front-facing camera to access the iPad's internal components.
    • Use masking tape to tape the lower edge of the screen to the frame to prevent the screen from slipping.
  22. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Prop up the screen: paso 23, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Prop up the screen: paso 23, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Prop up the screen: paso 23, imagen 3 de 3
    • This step shows one way to support the screen using masking tape. You can also turn the iPad sideways. Make sure not to strain the display cables with whatever method you choose.
    • Attach a long strip of masking tape to the top edge of the screen. Fold the tape over the edge and make sure that the tape is attached securely.
    • Attach the other end of the strip to the bottom edge of the iPad frame to hold the screen at an angle. Make sure the tape attaches securely to the frame.
  23. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Unfasten the logic board EMI shield screws: paso 24, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Unfasten the logic board EMI shield screws: paso 24, imagen 2 de 2
    • It's important to disconnect the battery before you proceed further. Detaching or connecting the display cables with the battery plugged in can cause a short that will destroy touchscreen functionality.
    • Use a Phillips screwdriver to remove the six screws securing the logic board EMI shield:
    • Two 2.4 mm-long screws
    • Four 1.2 mm-long screws
  24. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Remove the logic board EMI shield: paso 25, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Remove the logic board EMI shield: paso 25, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Remove the logic board EMI shield: paso 25, imagen 3 de 3
    • Lift the logic board EMI shield from the edge nearest the top of the iPad.
    • Peel up the EMI shield from the logic board.
    • This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when you reinstall it and screw it down.
    • Remove the logic board EMI shield.
  25. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Unfasten the battery connector screw: paso 26, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Unfasten the battery connector screw: paso 26, imagen 2 de 2
    • Use a Phillips screwdriver to remove the 1.6 mm-long screw securing the battery connector.
  26. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Battery connector information: paso 27, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Battery connector information: paso 27, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Battery connector information: paso 27, imagen 3 de 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has springs on the logic board that press down against the battery contact pads. You'll need to slide something thin and flexible between the contact points to disconnect the battery.
  27. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Create a battery blocker: paso 28, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Create a battery blocker: paso 28, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Create a battery blocker: paso 28, imagen 3 de 3
    • Use a piar of scissors to cut two 6 mm x 20 mm strips of a playing card to use as a battery blocker.
  28. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert the card strips: paso 29, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert the card strips: paso 29, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Insert the card strips: paso 29, imagen 3 de 3
    • Gently insert the card strips on each side of the battery connector as far as they will go.
    • You can also use an iFixit battery blocker. Be very careful and don't push the battery blocker underneath the connector with excessive force.
  29. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Unfasten the display connector bracket screws: paso 30, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Unfasten the display connector bracket screws: paso 30, imagen 2 de 2
    • Use a Phillips screwdriver to remove the four screws securing the display connector bracket:
    • Two 1.2 mm-long screws
  30. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Remove the display connector bracket: paso 31, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Remove the display connector bracket: paso 31, imagen 2 de 2
    • Remove the display connector bracket.
  31. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Disconnect the display cables: paso 32, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Disconnect the display cables: paso 32, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Disconnect the display cables: paso 32, imagen 3 de 3
    • Use the pointed end of a spudger to pry up and disconnect the display and digitizer cables from their logic board sockets.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • These cables are very delicate, and the connectors can damage easily if they're misaligned. When you reattach the cables to the logic board, try to have as much slack on the cables and gently press the connectors onto their sockets.
  32. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Remove the screen assembly: paso 33, imagen 1 de 1
    • Remove the screen assembly.
  33. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Unfasten the top bracket screws: paso 34, imagen 1 de 1
    • Use a Phillips screwdriver to remove the eight screws securing the top bracket:
    • Four 2.2 mm-long screws
  34. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Loosen the adhesive: paso 35, imagen 1 de 1
    • The top bracket is still held in place by the two black tapes securing it to the frame.
    • Apply a heated iOpener to the top bracket for 1 minute to loosen the adhesive.
  35. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Lift the top bracket: paso 36, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Lift the top bracket: paso 36, imagen 2 de 2
    • Slide the flat end of a spudger underneath the top bracket and lift it up until you can grab it with your fingers.
  36. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Remove the top bracket: paso 37, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Remove the top bracket: paso 37, imagen 2 de 2
    • Remove the top bracket.
  37. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Disconnect the front facing camera: paso 38, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Disconnect the front facing camera: paso 38, imagen 2 de 2
    • Use a spudger to disconnect the front facing camera flex cable by prying the connector straight up from its socket.
  38. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Free the front facing camera: paso 39, imagen 1 de 2 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Free the front facing camera: paso 39, imagen 2 de 2
    • The front facing camera is held in place by mild adhesive.
    • Use the flat end of a spudger to carefully pry up the front camera and to separate it from the frame.
  39. iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Remove the front facing camera: paso 40, imagen 1 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Remove the front facing camera: paso 40, imagen 2 de 3 iPad Pro 12.9" 2nd Gen Front Facing Camera Replacement, Remove the front facing camera: paso 40, imagen 3 de 3
    • The front camera cable is threaded underneath the frame.
    • Use a pair of tweezers to pull the front facing camera from underneath the frame and remove it.
Conclusión
If possible, turn on your device and test your repair before installing new adhesive and resealing.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Dominik Schnabelrauch
Miembro Desde 11/23/16
163,077 Reputación
649 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
140 Miembros
16,872 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 16
Todo El Tiempo: 107
