Introducción
Use this guide to remove and replace the battery in your iPad Mini 2 Wi-Fi.
If your battery is swollen, take appropriate precautions.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Take the first pick you inserted and slide it up toward the top corner of the iPad.
If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
Leave the opening pick in the iPad slightly past the front-facing camera.
Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
Antennas
Home button cavity
Digitizer cable
The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
If reusing the front panel assembly during reassembly, you will need to replace your display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
Run a thin string (like floss or fishing line) under the display, starting from the top then working your way down
Use a thin, flexible card or plastic money note to cut through the adhesive starting from the top.
Remove the following Phillips #00 screws from the display cable bracket:
One 2.7 mm screw
Two 1.4 mm screws
Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
Heat an iOpener and place it in the center of the back of the iPad case.
After about two minutes, remove the iOpener and place it on the right side of the iPad—the side farthest from the camera.
70 personas más completaron esta guía.
12 comentarios
I was able to change the battery but I will say the hardest part was heating the screen to get it off. The guide was great.
I have just installed replacement battery in iPad mini 2. Changing for about 2-1/2 hours only shows logo, and slightly warm.
battery shows same markings as original, I have also recently done iPhone 5 and Nexus 7 , both went well,. I'm concerned something is wrong with this installation, can anyone advise? Many thanks
Ross
Just completed my first attempt to replace the battery. All went well following the instructions here, but the photos could use some loving when it comes to some red arrows pointing to specific points. Also a little better contrast of separation points like adhesive tape areas and the lcd shield. other than that this was not to hard for me to complete especially with all of the added comments by others throughout the steps.
Next is the reverse process once I do some cleaning and prepare the replacement adhesive strips.
I would have really found it useful to have some detailed guidance on how to reapply the adhesive. The adhesive strips are packaged in such a way that it actually makes applying them much more difficult… unless there’s some trick that I couldn’t figure out. Hence, the value of some instructions.
The sheet with the adhesives has a clear cover over the side of the strips that adheres to the glass, with a blue cover strip and tab for easy removal on the side that adheres to the body. This would lead you to believe that you should adhere it to the glass first, and then press the glass onto the body. But the adhesive has many notches and curves and if you don’t get them aligned on the glass correctly, they could cover the light sensor or camera, interfere with the button, etc. Thus it seems you have to first stick it to the body, meaning you have completely exposed double-sided adhesive that you’re wrestling with, sticking to itself, etc.
If this is NOT how it’s done, some instructions would seem necessary.
