Saltar al contenido principal
iPad 5 Wi-Fi Case Button/Cable Replacement
Qué necesitas
  1. iPad 5 Wi-Fi Case Button/Cable Replacement, Heat the left edge: paso 1, imagen 1 de 1
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 5 Wi-Fi Case Button/Cable Replacement, Screen removal information: paso 2, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Screen removal information: paso 2, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Screen removal information: paso 2, imagen 3 de 3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 5 Wi-Fi Case Button/Cable Replacement, Anti-Clamp instructions: paso 3, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Anti-Clamp instructions: paso 3, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Anti-Clamp instructions: paso 3, imagen 3 de 3
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Elevate the iPad enough for the Anti-Clamp's arms to rest above and below the screen.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the left edge of the iPad—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  4. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 4, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 4, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 4, imagen 3 de 3
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  5. iPad 5 Wi-Fi Case Button/Cable Replacement, Insert an opening pick: paso 5, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Insert an opening pick: paso 5, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Insert an opening pick: paso 5, imagen 3 de 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  6. iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the left adhesive: paso 6, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the left adhesive: paso 6, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the left adhesive: paso 6, imagen 3 de 3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  7. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 7, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 7, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 7, imagen 3 de 3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  8. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 8, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 8, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 8, imagen 3 de 3
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  9. iPad 5 Wi-Fi Case Button/Cable Replacement, Heat the top edge: paso 9, imagen 1 de 1
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  10. iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the top left adhesive: paso 10, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the top left adhesive: paso 10, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the top left adhesive: paso 10, imagen 3 de 3
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  11. iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the top adhesive: paso 11, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the top adhesive: paso 11, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the top adhesive: paso 11, imagen 3 de 3
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  12. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 12, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 12, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 12, imagen 3 de 3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  13. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 13, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 13, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 13, imagen 3 de 3
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  14. iPad 5 Wi-Fi Case Button/Cable Replacement, Heat the right edge: paso 14, imagen 1 de 1
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  15. iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the top right adhesive: paso 15, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the top right adhesive: paso 15, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the top right adhesive: paso 15, imagen 3 de 3
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  16. iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the right adhesive: paso 16, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the right adhesive: paso 16, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the right adhesive: paso 16, imagen 3 de 3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  17. iPad 5 Wi-Fi Case Button/Cable Replacement, Heat the bottom edge: paso 17, imagen 1 de 1
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  18. iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the bottom left adhesive: paso 18, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the bottom left adhesive: paso 18, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the bottom left adhesive: paso 18, imagen 3 de 3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  19. iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the bottom adhesive: paso 19, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the bottom adhesive: paso 19, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the bottom adhesive: paso 19, imagen 3 de 3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  20. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 20, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 20, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 20, imagen 3 de 3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  21. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 21, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 21, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 21, imagen 3 de 3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  22. iPad 5 Wi-Fi Case Button/Cable Replacement, Heat the right edge: paso 22, imagen 1 de 1
  23. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 23, imagen 1 de 2 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 23, imagen 2 de 2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  24. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 24, imagen 1 de 2 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 24, imagen 2 de 2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  25. iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the right adhesive: paso 25, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the right adhesive: paso 25, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Separate the right adhesive: paso 25, imagen 3 de 3
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  26. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 26, imagen 1 de 2 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 26, imagen 2 de 2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  27. iPad 5 Wi-Fi Case Button/Cable Replacement, LCD: paso 27, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, LCD: paso 27, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, LCD: paso 27, imagen 3 de 3
    • Remove any tape obscuring the LCD screws.
  28. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 28, imagen 1 de 1
    • Remove the following Phillips screws securing the LCD.
    • Three 4.0 mm screws
    • One 4.8 mm screw
  29. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 29, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 29, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 29, imagen 3 de 3
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
    • Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
    • To reduce the risk of a short, you can insert a battery blocker or a modified opening pick to disconnect the battery.
    • Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage.
    • Slide the battery blocker underneath the battery connector area of the logic board, and leave it in place while you work.
    • If you are having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery.
  30. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 31, imagen 1 de 1
    • Remove the three 1.4 mm Phillips screws from the display cable bracket.
  31. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 32, imagen 1 de 2 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 32, imagen 2 de 2
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
  32. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 33, imagen 1 de 1
    • Remove the LCD.
  33. iPad 5 Wi-Fi Case Button/Cable Replacement, Front Panel Assembly: paso 34, imagen 1 de 2 iPad 5 Wi-Fi Case Button/Cable Replacement, Front Panel Assembly: paso 34, imagen 2 de 2
    • Remove any tape covering the home button ribbon cable connector.
  34. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 35, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 35, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 35, imagen 3 de 3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable horizontally out of the ZIF connector.
  35. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 36, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 36, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 36, imagen 3 de 3
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  36. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 37, imagen 1 de 2 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 37, imagen 2 de 2
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
    • Remove the front panel assembly.
    • During reassembly, wipe any dust or fingerprints off of the inside of the front panel assembly to ensure a clean display.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  37. iPad 5 Wi-Fi Case Button/Cable Replacement, Case Button/Cable: paso 39, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Case Button/Cable: paso 39, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement, Case Button/Cable: paso 39, imagen 3 de 3
    • Use the flat end of a spudger to flip up the retaining flap on the case buttons' ZIF connector on the logic board.
    • Use a pair of tweezers to grasp the case buttons' cable and remove it from the ZIF connector.
  38. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 40, imagen 1 de 1
    • Remove the following five Phillips #000 screws:
    • Three 2.3mm screws securing the volume button bracket
    • Two 2.3mm screws securing the power button bracket
  39. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 41, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 41, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 41, imagen 3 de 3
    • Use the pointed tip of a spudger to lift the power button out of its housing in the rear case.
    • At this point, the volume button bracket may lift out of its slot. Do not remove it entirely as the ribbon cable is still glued to the rear case.
  40. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 42, imagen 1 de 1
    • Lift but do not remove the volume buttons bracket from its housing in the rear case.
    • Lift the bracket just enough to expose the volume switches on the back of the button covers.
  41. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 43, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 43, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 43, imagen 3 de 3
    • Use the pointed tip of a spudger to nudge the two volume button covers out of their housing in the rear case.
  42. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 44, imagen 1 de 1
    • Remove the case buttons assembly.
    • At this point, the assembly comprises the volume buttons bracket, power button bracket, two volume control button covers, and the actual ribbon cable.
    • The following steps include instructions for isolating the ribbon cable for replacement.
  43. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 45, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 45, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 45, imagen 3 de 3
    • Gently peel the case buttons' ribbon cable off the metal volume button bracket.
  44. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 46, imagen 1 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 46, imagen 2 de 3 iPad 5 Wi-Fi Case Button/Cable Replacement: paso 46, imagen 3 de 3
    • Use tweezers to peel the power button switch off its plastic bracket.
    • Gently peel the two volume button switches off their respective button covers.
  45. iPad 5 Wi-Fi Case Button/Cable Replacement: paso 47, imagen 1 de 1
    • The case buttons ribbon cable remains.
Conclusión
4 personas más completaron esta guía.
Evan Noronha
Miembro Desde 02/05/15
218,976 Reputación
168 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 86
Todo El Tiempo: 3,980
