Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
iHome iPL8 Buttons Replacement
Qué necesitas
    1. iHome iPL8  Buttons Replacement, Battery: paso 1, imagen 1 de 1
      • Turn the device over to access the bottom panel.
      • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
      Pregunta a FixBot
      Agregar Comentario
    2. iHome iPL8  Buttons Replacement: paso 2, imagen 1 de 1
      • Using a Phillips #2 screwdriver, unscrew the captive screw.
      • Keep turning until the screw and the door are loose.
      Pregunta a FixBot
      Agregar Comentario
    3. iHome iPL8  Buttons Replacement: paso 3, imagen 1 de 1
      • Lift and remove the battery access panel.
      • The captive screw will remain attached to the panel.
      Pregunta a FixBot
      Agregar Comentario
    4. iHome iPL8  Buttons Replacement: paso 4, imagen 1 de 2 iHome iPL8  Buttons Replacement: paso 4, imagen 2 de 2
      • Gently press on the rim of the 3V battery.
      • Remove the 3V battery.
      Pregunta a FixBot
      Agregar Comentario
    1. iHome iPL8  Buttons Replacement, Lightning Connector: paso 5, imagen 1 de 1
      • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
      • Remove the four 6mm Phillips #2 screws.
      Pregunta a FixBot
      Agregar Comentario
    2. iHome iPL8  Buttons Replacement: paso 6, imagen 1 de 1
      • Remove the four round pads from the bottom of the device.
      • There are two additional 6mm Phillips #2 screws under the pads.
      • Using a Phillips #2 screwdriver, remove the two remaining screws.
      • Put your hand on the silver bottom case and gently pull it outward.
      Pregunta a FixBot
      Agregar Comentario
    3. iHome iPL8  Buttons Replacement: paso 7, imagen 1 de 2 iHome iPL8  Buttons Replacement: paso 7, imagen 2 de 2
      • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
      • Pull out the green circuit board on the two corners.
      • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
      Pregunta a FixBot
      Agregar Comentario
    4. iHome iPL8  Buttons Replacement: paso 8, imagen 1 de 2 iHome iPL8  Buttons Replacement: paso 8, imagen 2 de 2
      • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
      • Remove the two screws and the black cover.
      • Gently remove the lightning dock assembly.
      • The lightning dock assembly is connected to wires.
      Pregunta a FixBot
      Agregar Comentario
    5. iHome iPL8  Buttons Replacement: paso 9, imagen 1 de 3 iHome iPL8  Buttons Replacement: paso 9, imagen 2 de 3 iHome iPL8  Buttons Replacement: paso 9, imagen 3 de 3
      • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
      • Remove the back cover.
      • Use your fingers to reposition the lightning connector.
      • Make sure ALL of the lightning connector is exposed.
      Pregunta a FixBot
      Agregar Comentario
    1. iHome iPL8  Buttons Replacement, Buttons: paso 10, imagen 1 de 3 iHome iPL8  Buttons Replacement, Buttons: paso 10, imagen 2 de 3 iHome iPL8  Buttons Replacement, Buttons: paso 10, imagen 3 de 3
      • Locate the light brown, rectangular button board. Remove the five 2.5 mm Phillips #1 screws, four along the perimeter and one in the center.
      • Remove the brown button board.
      • There is a foam sheet underneath the button board. Use your hand to take it off and put it aside.
      Pregunta a FixBot
      Agregar Comentario
    2. iHome iPL8  Buttons Replacement: paso 11, imagen 1 de 2 iHome iPL8  Buttons Replacement: paso 11, imagen 2 de 2
      • There are two rows of buttons clipped on to the small, circular, black columns.
      • Gently unclip the two rows of buttons and remove them.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Chen Zhong
Miembro Desde 02/05/19
569 Reputación
4 Guías creadas
Equipo
UC Davis, Team S18-G5, Lore Winter 2019 Miembro de UC Davis, Team S18-G5, Lore Winter 2019
UCD-LORE-W19S18G5
Miembros de 3
8 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 519
