Introducción
Use this guide to replace the loudspeaker on your Xiaomi Redmi Note 9.
You’ll need replacement adhesive to reattach components when reassembling the device.
Qué necesitas
Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the left edge of the phone.
Press directly into the hole to eject the SIM card tray.
Remove the SIM card tray.
Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the screen, as close to the edge as possible.
Lift the phone assembly with the suction handle to create a small gap between the assembly and the back cover.
Insert an opening pick in a steep angle into the gap you created. This might require some force.
Slide the opening pick to the bottom right corner to slice the adhesive and release the plastic clips holding the back cover in place.
Insert a second opening pick in a steep angle at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to release the plastic clips and to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick in a steep angle at the bottom left corner of your phone.
Slide the opening pick along the left edge of your phone to release the plastic clips and slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Flip your Redmi Note 9 over.
Carefully fold the back cover to the right side of the phone assembly like you would open a book from the back.
Slide the back cover underneath the phone assembly so that the phone assembly overlaps about one third of the back cover and the fingerprint cable is not strained.
Use a Phillips screwdriver to remove the eleven 3.9 mm-long screws securing the motherboard cover.
Insert the tip of an opening pick underneath the bottom left edge of the motherboard cover.
Pry up the motherboard cover.
Use a spudger to disconnect the fingerprint cable by prying the connector straight up from its socket.
Separate the phone assembly from the back cover.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Use a Phillips screwdriver to remove the seven 3.9 mm-long screws securing the loudspeaker assembly.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
4 personas más completaron esta guía.
4 comentarios
Yesterday I completed replacing the loudspeaker for my note 9 using the instructions in this guide.
Although I had to reheat the i opener a few times I found it very useful to use a thermometer to check on the build up of heat in the phone.
Once I got the back off it was just a matter of following the instructions step by step.
I think the instructions are excellent!
Thank you!
