Saltar al contenido principal
Xiaomi Poco M3 Back Cover Replacement
Qué necesitas
  1. Xiaomi Poco M3 Back Cover Replacement, SIM Card tray removal: paso 1, imagen 1 de 3 Xiaomi Poco M3 Back Cover Replacement, SIM Card tray removal: paso 1, imagen 2 de 3 Xiaomi Poco M3 Back Cover Replacement, SIM Card tray removal: paso 1, imagen 3 de 3
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located near the top left corner of the Poco M3.
    • Press firmly to eject the SIM card tray.
    • Remove the SIM card tray from the phone by pulling it out of the phone assembly.
    • If the tray holds a SIM card it will fall out easily.
    • When reinserting the SIM card, make sure it's in the correct orientation inside the SIM card tray.
    • A thin rubber gasket around the SIM card tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM card tray to protect your Poco M3's internal components.
  2. Xiaomi Poco M3 Back Cover Replacement, Insert a spudger: paso 2, imagen 1 de 3 Xiaomi Poco M3 Back Cover Replacement, Insert a spudger: paso 2, imagen 2 de 3 Xiaomi Poco M3 Back Cover Replacement, Insert a spudger: paso 2, imagen 3 de 3
    • Insert a spudger into the charging port at a steep angle.
    • Do not insert the spudger in a flat angle like you would do with a charging cable to avoid damaging the charging port.
    • Use the spudger to create a gap between the phone assembly and the back cover by prying the back cover away from the bottom edge of the screen.
  3. Xiaomi Poco M3 Back Cover Replacement, Insert an opening pick: paso 3, imagen 1 de 3 Xiaomi Poco M3 Back Cover Replacement, Insert an opening pick: paso 3, imagen 2 de 3 Xiaomi Poco M3 Back Cover Replacement, Insert an opening pick: paso 3, imagen 3 de 3
    • Insert an opening pick into the gap between the phone assembly and the back cover.
    • Remove the spudger.
  4. Xiaomi Poco M3 Back Cover Replacement, Release the plastic clips: paso 4, imagen 1 de 3 Xiaomi Poco M3 Back Cover Replacement, Release the plastic clips: paso 4, imagen 2 de 3 Xiaomi Poco M3 Back Cover Replacement, Release the plastic clips: paso 4, imagen 3 de 3
    • Slide the opening pick to the bottom left corner of the phone to release the plastic clips holding the back cover in place.
    • Slide the opening pick around the bottom left corner.
  5. Xiaomi Poco M3 Back Cover Replacement: paso 5, imagen 1 de 3 Xiaomi Poco M3 Back Cover Replacement: paso 5, imagen 2 de 3 Xiaomi Poco M3 Back Cover Replacement: paso 5, imagen 3 de 3
    • Slide the opening pick along the left edge of the Poco M3 to release the plastic clips.
  6. Xiaomi Poco M3 Back Cover Replacement: paso 6, imagen 1 de 3 Xiaomi Poco M3 Back Cover Replacement: paso 6, imagen 2 de 3 Xiaomi Poco M3 Back Cover Replacement: paso 6, imagen 3 de 3
    • Slide the opening pick around the top left corner to release the plastic clips.
    • Slide the opening pick along the top edge of the phone to release the plastic clips holding the back cover in place.
  7. Xiaomi Poco M3 Back Cover Replacement: paso 7, imagen 1 de 2 Xiaomi Poco M3 Back Cover Replacement: paso 7, imagen 2 de 2
    • Slide the opening pick around the top right corner to release the plastic clips.
    • Leave the opening pick inserted above the volume buttons.
    • Avoid using your opening pick in the area where the physical buttons are located. There's a flex cable running to the motherboard which can be easily torn.
  8. Xiaomi Poco M3 Back Cover Replacement: paso 8, imagen 1 de 3 Xiaomi Poco M3 Back Cover Replacement: paso 8, imagen 2 de 3 Xiaomi Poco M3 Back Cover Replacement: paso 8, imagen 3 de 3
    • Insert another opening pick into the gap at the bottom edge of your phone.
    • Slide the opening pick around the bottom right corner to release the plastic clips securing the back cover.
    • Slide the opening pick along the right edge of the phone to release the remaining plastic clips. Stop just below the fingerprint reader.
  9. Xiaomi Poco M3 Back Cover Replacement: paso 9, imagen 1 de 2 Xiaomi Poco M3 Back Cover Replacement: paso 9, imagen 2 de 2
    • Remove the opening picks and flip the phone over.
    • Open up the phone by swinging the back cover up from the right side, like the front cover of a book.
    • Avoid tensioning the fingerprint flex cable during this procedure.
  10. Xiaomi Poco M3 Back Cover Replacement, Free the fingerprint sensor: paso 10, imagen 1 de 3 Xiaomi Poco M3 Back Cover Replacement, Free the fingerprint sensor: paso 10, imagen 2 de 3 Xiaomi Poco M3 Back Cover Replacement, Free the fingerprint sensor: paso 10, imagen 3 de 3
    • Use tweezers to lift the fingerprint sensor rubber gasket off of the top plastic pin.
    • Use tweezers to lift the fingerprint sensor rubber gasket off of the bottom plastic pin.
    • Take care to not scratch or yank the fingerprint sensor ribbon cable or pierce the fingerprint senor rubber gasket while removing it.
    • Carefully peel the fingerprint cable off the back cover.
  11. Xiaomi Poco M3 Back Cover Replacement, Remove the back cover: paso 11, imagen 1 de 1
    • Remove the back cover.
Conclusión
Removal didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
4 personas más completaron esta guía.
Dominik Schnabelrauch
Miembro Desde 11/23/16
203,632 Reputación
682 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
17,146 Guías creadas
Un comentario
Thank u Mr Dominic
Telle me how i Can Clean the sound holes at my phone Poco m3
Mouh Elyali - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 23
Ultimos 30 días: 91
Todo El Tiempo: 2,880
