Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Xbox 360 Wireless Controller Bottom Panel Replacement
Qué necesitas
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Battery: paso 1, imagen 1 de 2 Xbox 360 Wireless Controller Bottom Panel Replacement, Battery: paso 1, imagen 2 de 2
      • Depress the battery release button on the top of the controller.
      • Remove the battery holder from the controller.
      • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
      Pregunta a FixBot
      Agregar Comentario
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Rear Case: paso 2, imagen 1 de 1
      Herramienta utilizada en este paso:
      • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
      Pregunta a FixBot
      Agregar Comentario
    2. Xbox 360 Wireless Controller Bottom Panel Replacement: paso 3, imagen 1 de 1
      • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
      Pregunta a FixBot
      Agregar Comentario
    3. Xbox 360 Wireless Controller Bottom Panel Replacement: paso 4, imagen 1 de 2 Xbox 360 Wireless Controller Bottom Panel Replacement: paso 4, imagen 2 de 2
      Spudger
      $2.99
      • Insert a Spudger between the front and rear cases along the left edge of the controller.
      • Rotate the spudger toward the front of the controller, prying the two cases apart.
      Pregunta a FixBot
      Agregar Comentario
    4. Xbox 360 Wireless Controller Bottom Panel Replacement: paso 5, imagen 1 de 2 Xbox 360 Wireless Controller Bottom Panel Replacement: paso 5, imagen 2 de 2
      • Insert a spudger between the front and rear cases, near the headphone jack.
      • Rotate the spudger toward the front of the controller to pry the two cases apart.
      Pregunta a FixBot
      Agregar Comentario
    5. Xbox 360 Wireless Controller Bottom Panel Replacement: paso 6, imagen 1 de 2 Xbox 360 Wireless Controller Bottom Panel Replacement: paso 6, imagen 2 de 2
      • Grasp the controller by the battery compartment and the headphone jack.
      • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
      • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
      Pregunta a FixBot
      Agregar Comentario
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Vibration Motors: paso 7, imagen 1 de 2 Xbox 360 Wireless Controller Bottom Panel Replacement, Vibration Motors: paso 7, imagen 2 de 2
      • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
      • Lift the vibration motor out of the front case.
      Pregunta a FixBot
      Agregar Comentario
    2. Xbox 360 Wireless Controller Bottom Panel Replacement: paso 8, imagen 1 de 2 Xbox 360 Wireless Controller Bottom Panel Replacement: paso 8, imagen 2 de 2
      • Remove the vibration motor from the other side of the controller using the same method previously described.
      • The left motor has significantly more counterweight than the right motor.
      Pregunta a FixBot
      Agregar Comentario
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Logic Board: paso 9, imagen 1 de 2 Xbox 360 Wireless Controller Bottom Panel Replacement, Logic Board: paso 9, imagen 2 de 2
      • Lifting from the headphone jack and power plug, remove the logic board from the front case.
      Pregunta a FixBot
      Agregar Comentario
    1. Xbox 360 Wireless Controller Bottom Panel Replacement, Bottom Panel: paso 10, imagen 1 de 2 Xbox 360 Wireless Controller Bottom Panel Replacement, Bottom Panel: paso 10, imagen 2 de 2
      • Lift the bumper panel off of the front case.
      Pregunta a FixBot
      Agregar Comentario
    2. Xbox 360 Wireless Controller Bottom Panel Replacement: paso 11, imagen 1 de 1
      • Remove the rubber pad from the back of the D-pad.
      Pregunta a FixBot
      Agregar Comentario
    3. Xbox 360 Wireless Controller Bottom Panel Replacement: paso 12, imagen 1 de 1
      • Remove the two 7.0 mm silver Phillips screws from the back of the D-pad.
      Pregunta a FixBot
      Agregar Comentario
    4. Xbox 360 Wireless Controller Bottom Panel Replacement: paso 13, imagen 1 de 2 Xbox 360 Wireless Controller Bottom Panel Replacement: paso 13, imagen 2 de 2
      • The D-pad is secured to its backing by two diagonal clips, shown in red.
      • Use a pair of tweezers and squeeze the clips together to release the D-pad from its backing.
      Pregunta a FixBot
      Agregar Comentario
    5. Xbox 360 Wireless Controller Bottom Panel Replacement: paso 14, imagen 1 de 2 Xbox 360 Wireless Controller Bottom Panel Replacement: paso 14, imagen 2 de 2
      • Lift the D-pad backing out of its compartment on the front case.
      • The D-pad remains below the front case.
      • The D-pad will fall once its backing is removed. Be sure to support it as you remove the backing.
      • The backing is slotted to its compartment to ensure that it will always be aligned properly.
      Pregunta a FixBot
      Agregar Comentario
    6. Xbox 360 Wireless Controller Bottom Panel Replacement: paso 15, imagen 1 de 1
      • Remove the rubber pad from the back of the input buttons.
      Pregunta a FixBot
      Agregar Comentario
    7. Xbox 360 Wireless Controller Bottom Panel Replacement: paso 16, imagen 1 de 2 Xbox 360 Wireless Controller Bottom Panel Replacement: paso 16, imagen 2 de 2
      • Using a pair or tweezers, remove the following buttons from the front panel:
      • A Button
      • B Button
      • X Button
      • Y Button
      • Start Button
      • Select Button
      • Guide Button
      Pregunta a FixBot
      Agregar Comentario
    8. Xbox 360 Wireless Controller Bottom Panel Replacement: paso 17, imagen 1 de 1
      • Using a pair of tweezers, remove the LED ring from the front panel.
      Pregunta a FixBot
      Agregar Comentario
    9. Xbox 360 Wireless Controller Bottom Panel Replacement: paso 18, imagen 1 de 3 Xbox 360 Wireless Controller Bottom Panel Replacement: paso 18, imagen 2 de 3 Xbox 360 Wireless Controller Bottom Panel Replacement: paso 18, imagen 3 de 3
      • Insert a spudger between the lower panel and front case.
      • Slide the spudger along the gap between the two case components.
      • Lift the lower panel off of the front case.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
20 personas más completaron esta guía.
Brett Hartt
Miembro Desde 04/12/10
132,314 Reputación
144 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 123
77,882 Guías creadas
2Guía Comentarios
I have 2 remote controllers of X box one which is not working.
ravi.gopalakrishnan - Contestar Compartir
Ib rb button
Abdou Fegas - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 19
Ultimos 30 días: 92
Todo El Tiempo: 20,063
