Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Xbox 360 RF Module Replacement
Qué necesitas
  1. Xbox 360 RF Module Replacement, Hard Drive: paso 1, imagen 1 de 2 Xbox 360 RF Module Replacement, Hard Drive: paso 1, imagen 2 de 2
    • Grasp the hard drive assembly and press the release button while lifting its front edge.
    • Remove the hard drive assembly from the top vent.
    Pregunta a FixBot
    Agregar Comentario
  2. Xbox 360 RF Module Replacement, Bottom Vent: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Xbox 360 Opening Tool
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
    Pregunta a FixBot
    Agregar Comentario
  3. Xbox 360 RF Module Replacement: paso 3, imagen 1 de 3 Xbox 360 RF Module Replacement: paso 3, imagen 2 de 3 Xbox 360 RF Module Replacement: paso 3, imagen 3 de 3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
    Pregunta a FixBot
    Agregar Comentario
  4. Xbox 360 RF Module Replacement: paso 4, imagen 1 de 2 Xbox 360 RF Module Replacement: paso 4, imagen 2 de 2
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
    Pregunta a FixBot
    Agregar Comentario
  5. Xbox 360 RF Module Replacement: paso 5, imagen 1 de 2 Xbox 360 RF Module Replacement: paso 5, imagen 2 de 2
    • Repeat the same process to release the two center clips on the bottom vent.
    Pregunta a FixBot
    Agregar Comentario
  6. Xbox 360 RF Module Replacement: paso 6, imagen 1 de 2 Xbox 360 RF Module Replacement: paso 6, imagen 2 de 2
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
    Pregunta a FixBot
    Agregar Comentario
  7. Xbox 360 RF Module Replacement: paso 7, imagen 1 de 1
    • Remove the bottom vent from the 360.
    Pregunta a FixBot
    Agregar Comentario
  8. Xbox 360 RF Module Replacement, Faceplate: paso 8, imagen 1 de 2 Xbox 360 RF Module Replacement, Faceplate: paso 8, imagen 2 de 2
    • Insert the flat edge of a spudger between the faceplate and the outer casing near the power button.
    • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
    • You may also accomplish this task by using the edge of the Xbox 360 opening tool, but it may scratch the plastic case.
    • Alternatively, you can use your hands to carefully pull the faceplate away from the Xbox.
    Pregunta a FixBot
    Agregar Comentario
  9. Xbox 360 RF Module Replacement: paso 9, imagen 1 de 1
    • Repeat the same motions as previously mentioned to release the left side of the faceplate.
    Pregunta a FixBot
    Agregar Comentario
  10. Xbox 360 RF Module Replacement: paso 10, imagen 1 de 1
    • Remove the faceplate from the front face of the console.
    Pregunta a FixBot
    Agregar Comentario
  11. Xbox 360 RF Module Replacement, Top Vent: paso 11, imagen 1 de 2 Xbox 360 RF Module Replacement, Top Vent: paso 11, imagen 2 de 2
    • Stand the console vertically with the top edge facing up.
    • The top vent is secured to the console via clips. The first two clips are located underneath the top vent closest to the faceplate, as shown in the pictures.
    Pregunta a FixBot
    Agregar Comentario
  12. Xbox 360 RF Module Replacement: paso 12, imagen 1 de 2 Xbox 360 RF Module Replacement: paso 12, imagen 2 de 2
    • Insert the flat end of a spudger into the small gaps previously mentioned to release the clips.
    • You may also use the long finger of an Xbox 360 opening tool to accomplish this task.
    Pregunta a FixBot
    Agregar Comentario
  13. Xbox 360 RF Module Replacement: paso 13, imagen 1 de 3 Xbox 360 RF Module Replacement: paso 13, imagen 2 de 3 Xbox 360 RF Module Replacement: paso 13, imagen 3 de 3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the top vent. Their locations are highlighted in red.
    Pregunta a FixBot
    Agregar Comentario
  14. Xbox 360 RF Module Replacement: paso 14, imagen 1 de 2 Xbox 360 RF Module Replacement: paso 14, imagen 2 de 2
    • To release the clips, work from the middle of the top vent.
    • While slightly lifting the front edge of the top vent, use the tip of a spudger to push the clips closest to the center of the top vent towards the inside of the console.
    Pregunta a FixBot
    Agregar Comentario
  15. Xbox 360 RF Module Replacement: paso 15, imagen 1 de 1
    • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox's upper case.
    Pregunta a FixBot
    Agregar Comentario
  16. Xbox 360 RF Module Replacement: paso 16, imagen 1 de 2 Xbox 360 RF Module Replacement: paso 16, imagen 2 de 2
    • The last clip is hidden underneath the rubber foot nearest the back of the console.
    • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox.
    • Remove the top vent from the 360.
    Pregunta a FixBot
    Agregar Comentario
  17. Xbox 360 RF Module Replacement, Lower Case: paso 17, imagen 1 de 1
    • Stand the console vertically with the top edge facing down.
    • Carefully peel the warranty sticker off the console.
    Pregunta a FixBot
    Agregar Comentario
  18. Xbox 360 RF Module Replacement: paso 18, imagen 1 de 3 Xbox 360 RF Module Replacement: paso 18, imagen 2 de 3 Xbox 360 RF Module Replacement: paso 18, imagen 3 de 3
    • The upper and lower cases are attached via several latches, located in the front and back of the console. These latches must be disengaged to separate the upper case from the console.
    • Use the flat end of a spudger to release the following latches:
    • Above the front-facing USB ports.
    • Beneath the front-facing USB ports.
    • Above the Memory Unit slots.
    Pregunta a FixBot
    Agregar Comentario
  19. Xbox 360 RF Module Replacement: paso 19, imagen 1 de 1
    • Insert the flat end of a spudger and pry upwards to release the last remaining latch located above the eject button.
    Pregunta a FixBot
    Agregar Comentario
  20. Xbox 360 RF Module Replacement: paso 20, imagen 1 de 1
    • Slightly lift the front portion of the lower case to ensure that the latches in the front have been completely released.
    Pregunta a FixBot
    Agregar Comentario
  21. Xbox 360 RF Module Replacement: paso 21, imagen 1 de 2 Xbox 360 RF Module Replacement: paso 21, imagen 2 de 2
    • The upper and lower cases are held together by seven release latches located on the back of the console. Their locations are highlighted in red.
    Pregunta a FixBot
    Agregar Comentario
  22. Xbox 360 RF Module Replacement: paso 22, imagen 1 de 3 Xbox 360 RF Module Replacement: paso 22, imagen 2 de 3 Xbox 360 RF Module Replacement: paso 22, imagen 3 de 3
    • Press the Xbox 360 opening tool down into the clips securing the lower case to the upper case near the I/O ports.
    • While pressing down on the tool, push the lower and upper cases apart to separate the retaining clips.
    Pregunta a FixBot
    Agregar Comentario
  23. Xbox 360 RF Module Replacement: paso 23, imagen 1 de 2 Xbox 360 RF Module Replacement: paso 23, imagen 2 de 2
    • While pushing the upper and lower cases apart, use the tip of a spudger or the finger of an Xbox 360 opening tool to push the long clip highlighted in red toward the center of the 360.
    • The clip should release, leaving the clips near the power connector as the only thing holding the upper and lower cases together.
    Pregunta a FixBot
    Agregar Comentario
  24. Xbox 360 RF Module Replacement: paso 24, imagen 1 de 1
    • Press the Xbox 360 opening tool down into the two remaining clips near the power connector.
    • Push the upper and lower cases apart to fully release the retaining clips.
    Pregunta a FixBot
    Agregar Comentario
  25. Xbox 360 RF Module Replacement: paso 25, imagen 1 de 1
    • Orient the console so that the front portion is facing downwards.
    • Grasp the back portion of the lower case and lift it upwards to separate it from the console.
    • Be careful not to excessively bend the lower case near the power plug, as it can crack easily.
    Pregunta a FixBot
    Agregar Comentario
  26. Xbox 360 RF Module Replacement, Eject Button: paso 26, imagen 1 de 2 Xbox 360 RF Module Replacement, Eject Button: paso 26, imagen 2 de 2
    • Use the tip of a spudger to release the clip securing the eject button to the metal casing.
    • Insert the flat end of a spudger between the eject button and the optical drive.
    • Pry the eject button off its retaining posts and remove it from the 360.
    • This can also be accomplished using an Xbox 360 opening tool.
    Pregunta a FixBot
    Agregar Comentario
  27. Xbox 360 RF Module Replacement, Upper Case: paso 27, imagen 1 de 1
    • Remove the six silver 64 mm T10 Torx screws securing the upper case to the metal casing.
    Pregunta a FixBot
    Agregar Comentario
  28. Xbox 360 RF Module Replacement: paso 28, imagen 1 de 1
    • Orient the console so that the upper case is facing upwards.
    • Lift the upper case straight up and remove it from the console.
    Pregunta a FixBot
    Agregar Comentario
  29. Xbox 360 RF Module Replacement, RF Module: paso 29, imagen 1 de 3 Xbox 360 RF Module Replacement, RF Module: paso 29, imagen 2 de 3 Xbox 360 RF Module Replacement, RF Module: paso 29, imagen 3 de 3
    • Use the flat end of a spudger to release the clips securing the plastic RF module shield along the top and the left edge of the power button board.
    • Lift and remove the RF module shield from the console.
    Pregunta a FixBot
    Agregar Comentario
  30. Xbox 360 RF Module Replacement: paso 30, imagen 1 de 1
    • Remove three 5.6 mm T8 Torx screws securing the RF module to the metal chassis.
    Pregunta a FixBot
    Agregar Comentario
  31. Xbox 360 RF Module Replacement: paso 31, imagen 1 de 2 Xbox 360 RF Module Replacement: paso 31, imagen 2 de 2
    • Grasp the RF module and lift it straight up to disconnect it from its socket on the motherboard.
    • Remove the RF module from the console.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
28 personas más completaron esta guía.
1Guía Comentario
Just out of curiosity, what does it mean when there is the marking AC above the chipset to the right of the Microsoft logo? Is it a different kind of board? Or just a variant on the console lifetime?
Jonathon Theys - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 24
Ultimos 30 días: 90
Todo El Tiempo: 46,310
