Saltar al contenido principal
Whirlpool Refrigerator Control Board Replacement
Qué necesitas
  1. Whirlpool Refrigerator Control Board Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Control Board Replacement, Unfasten the dispenser panels: paso 2, imagen 1 de 2 Whirlpool Refrigerator Control Board Replacement, Unfasten the dispenser panels: paso 2, imagen 2 de 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Remove the screw(s) securing the two dispenser panels.
  3. Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: paso 3, imagen 1 de 3 Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: paso 3, imagen 2 de 3 Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: paso 3, imagen 3 de 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. Whirlpool Refrigerator Control Board Replacement, Unfasten the control board: paso 4, imagen 1 de 1
    • Remove the screw(s) securing the control board.
  5. Whirlpool Refrigerator Control Board Replacement: paso 5, imagen 1 de 3 Whirlpool Refrigerator Control Board Replacement: paso 5, imagen 2 de 3 Whirlpool Refrigerator Control Board Replacement: paso 5, imagen 3 de 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: paso 6, imagen 1 de 3 Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: paso 6, imagen 2 de 3 Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: paso 6, imagen 3 de 3
    • Disconnect the connectors attached to the control board.
  7. Whirlpool Refrigerator Control Board Replacement, Remove the control board: paso 7, imagen 1 de 1
    • Remove the control board.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
Una persona más ha completado esta guía.
nicO
Miembro Desde 04/14/15
15,945 Reputación
89 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 20
Ultimos 30 días: 187
Todo El Tiempo: 4,997
