Saltar al contenido principal
WRS315SDHW Dispenser Assembly Replacement
Qué necesitas
  1. WRS315SDHW Dispenser Assembly Replacement, Safety precautions: paso 1, imagen 1 de 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Dispenser Assembly Replacement, Unfasten the dispenser panels: paso 2, imagen 1 de 2 WRS315SDHW Dispenser Assembly Replacement, Unfasten the dispenser panels: paso 2, imagen 2 de 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
  3. WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser panels: paso 3, imagen 1 de 3 WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser panels: paso 3, imagen 2 de 3 WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser panels: paso 3, imagen 3 de 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. WRS315SDHW Dispenser Assembly Replacement, Unfasten the control board: paso 4, imagen 1 de 1
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
  5. WRS315SDHW Dispenser Assembly Replacement: paso 5, imagen 1 de 3 WRS315SDHW Dispenser Assembly Replacement: paso 5, imagen 2 de 3 WRS315SDHW Dispenser Assembly Replacement: paso 5, imagen 3 de 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. WRS315SDHW Dispenser Assembly Replacement, Disconnect the control board: paso 6, imagen 1 de 3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the control board: paso 6, imagen 2 de 3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the control board: paso 6, imagen 3 de 3
    • Disconnect the large connector attached to the right edge of the control board.
  7. WRS315SDHW Dispenser Assembly Replacement: paso 7, imagen 1 de 2 WRS315SDHW Dispenser Assembly Replacement: paso 7, imagen 2 de 2
    • Disconnect the small connector attached to the left edge of the control board.
  8. WRS315SDHW Dispenser Assembly Replacement, Remove the control board: paso 8, imagen 1 de 1
    • Remove the control board.
  9. WRS315SDHW Dispenser Assembly Replacement, Remove the plastic clip: paso 9, imagen 1 de 3 WRS315SDHW Dispenser Assembly Replacement, Remove the plastic clip: paso 9, imagen 2 de 3 WRS315SDHW Dispenser Assembly Replacement, Remove the plastic clip: paso 9, imagen 3 de 3
    • Use a flathead screwdriver, or a similar tool, to pry up the plastic clip securing the water hose.
    • Remove the plastic clip.
  10. WRS315SDHW Dispenser Assembly Replacement, Disconnect the water hose: paso 10, imagen 1 de 3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the water hose: paso 10, imagen 2 de 3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the water hose: paso 10, imagen 3 de 3
    • Use a flathead screwdriver, or a similar tool, to pry up the water hose enough to grip it with your fingers.
    • Pull the water hose straight up to disconnect it.
  11. WRS315SDHW Dispenser Assembly Replacement, Reposition the cables: paso 11, imagen 1 de 2 WRS315SDHW Dispenser Assembly Replacement, Reposition the cables: paso 11, imagen 2 de 2
    • Reposition the cables so they lay in front of the top plastic clip.
  12. WRS315SDHW Dispenser Assembly Replacement, Unclip the dispenser assembly: paso 12, imagen 1 de 3 WRS315SDHW Dispenser Assembly Replacement, Unclip the dispenser assembly: paso 12, imagen 2 de 3 WRS315SDHW Dispenser Assembly Replacement, Unclip the dispenser assembly: paso 12, imagen 3 de 3
    • There are two plastic clips that secure the dispenser assembly in the chassis.
    • Use a flathead screwdriver, or a similar tool, to press the plastic clip toward the dispenser assembly.
    • Repeat for the other plastic clip to completely separate the dispenser assembly from the chassis.
  13. WRS315SDHW Dispenser Assembly Replacement, Reposition the dispenser assembly: paso 13, imagen 1 de 3 WRS315SDHW Dispenser Assembly Replacement, Reposition the dispenser assembly: paso 13, imagen 2 de 3 WRS315SDHW Dispenser Assembly Replacement, Reposition the dispenser assembly: paso 13, imagen 3 de 3
    • Pull the dispenser assembly away from the chassis enough to access its connectors.
  14. WRS315SDHW Dispenser Assembly Replacement, Disconnect the dispenser assembly: paso 14, imagen 1 de 3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the dispenser assembly: paso 14, imagen 2 de 3 WRS315SDHW Dispenser Assembly Replacement, Disconnect the dispenser assembly: paso 14, imagen 3 de 3
    • While performing this step, support the dispenser assembly so it doesn't fall.
    • Disconnect the connector attached to the dispenser assembly.
  15. WRS315SDHW Dispenser Assembly Replacement, Remove the dispenser assembly: paso 15, imagen 1 de 1
    • Remove the dispenser assembly.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
Una persona más ha completado esta guía.
nicO
Miembro Desde 04/14/15
15,927 Reputación
89 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
45 Miembros
700 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 11
Ultimos 30 días: 23
Todo El Tiempo: 279
