Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
VTech InnoTab Max Screen Replacement
Qué necesitas
    1. VTech InnoTab Max Screen Replacement, Cover: paso 1, imagen 1 de 3 VTech InnoTab Max Screen Replacement, Cover: paso 1, imagen 2 de 3 VTech InnoTab Max Screen Replacement, Cover: paso 1, imagen 3 de 3
      • Remove all screw caps from the back panel using a metal spudger.
      Pregunta a FixBot
      Agregar Comentario
    2. VTech InnoTab Max Screen Replacement: paso 2, imagen 1 de 3 VTech InnoTab Max Screen Replacement: paso 2, imagen 2 de 3 VTech InnoTab Max Screen Replacement: paso 2, imagen 3 de 3
      • Next remove all of the now uncovered screws.
      • If there is a cartridge in the device make sure to remove it.
      Pregunta a FixBot
      Agregar Comentario
    3. VTech InnoTab Max Screen Replacement: paso 3, imagen 1 de 2 VTech InnoTab Max Screen Replacement: paso 3, imagen 2 de 2
      • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
      Pregunta a FixBot
      Agregar Comentario
    4. VTech InnoTab Max Screen Replacement: paso 4, imagen 1 de 2 VTech InnoTab Max Screen Replacement: paso 4, imagen 2 de 2
      • Here you can see the back cover has been fully removed and you can now access the front cover.
      • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
      Pregunta a FixBot
      Agregar Comentario
    1. VTech InnoTab Max Screen Replacement, Battery: paso 5, imagen 1 de 1
      • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
      Pregunta a FixBot
      Agregar Comentario
    2. VTech InnoTab Max Screen Replacement: paso 6, imagen 1 de 3 VTech InnoTab Max Screen Replacement: paso 6, imagen 2 de 3 VTech InnoTab Max Screen Replacement: paso 6, imagen 3 de 3
      Herramienta utilizada en este paso:
      Plastic Cards
      $2.99
      • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
      • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
      • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
      Pregunta a FixBot
      Agregar Comentario
    3. VTech InnoTab Max Screen Replacement: paso 7, imagen 1 de 3 VTech InnoTab Max Screen Replacement: paso 7, imagen 2 de 3 VTech InnoTab Max Screen Replacement: paso 7, imagen 3 de 3
      • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    4. VTech InnoTab Max Screen Replacement: paso 8, imagen 1 de 1
      • The battery is now fully disconnected.
      Pregunta a FixBot
      Agregar Comentario
    1. VTech InnoTab Max Screen Replacement, Screen: paso 9, imagen 1 de 2 VTech InnoTab Max Screen Replacement, Screen: paso 9, imagen 2 de 2
      • In order to unlock the screen you need to remove the 4 pins that can be seen in the picture.
      • To remove simply just turn and pull them out. Use a metal or nylon spudger if they are too small to grip.
      Pregunta a FixBot
      Agregar Comentario
    2. VTech InnoTab Max Screen Replacement: paso 10, imagen 1 de 3 VTech InnoTab Max Screen Replacement: paso 10, imagen 2 de 3 VTech InnoTab Max Screen Replacement: paso 10, imagen 3 de 3
      • Once the pins are removed the screen should be loose from the frame and only connected by the brown film pictured.
      Pregunta a FixBot
      Agregar Comentario
    3. VTech InnoTab Max Screen Replacement: paso 11, imagen 1 de 3 VTech InnoTab Max Screen Replacement: paso 11, imagen 2 de 3 VTech InnoTab Max Screen Replacement: paso 11, imagen 3 de 3
      • In order to completely remove the screen you need to unclip the film from the motherboard by simply using a pair of tweezers and gently pulling.
      • Be careful not to tear the film when pulling.
      Pregunta a FixBot
      Agregar Comentario
    4. VTech InnoTab Max Screen Replacement: paso 12, imagen 1 de 2 VTech InnoTab Max Screen Replacement: paso 12, imagen 2 de 2
      • Once unclipped from the motherboard the screen should be entirely free from the device
      Pregunta a FixBot
      Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Equipo
USF Tampa, Team S5-G5, Lacy Spring 2017 Miembro de USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
Miembros de 3
10 Guías creadas
5Guía Comentarios
Where can I buy a screen
Damien Hennigan - Contestar Compartir
Where can I buy a screen? Can't find any sites that sell the innotab Max screens.
i can not seem to find a replacement screen online, where can i buy one? Innotab Max from Vtech… HELP please..
fanny_muller - Contestar Compartir
Hello, where can i buy a KIDICOM MAX Rose Screen. Our daughter here is broken!.thanks a lot!
hans.depre@gmail.com
Hans Depre - Contestar Compartir
bonjour je cherche a raplasser l ecran du kidicom max car le mien ne salume plus pas merci
theobald - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 41
Todo El Tiempo: 5,850
