Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
VTech InnoTab Max Battery Replacement
Qué necesitas
    1. VTech InnoTab Max Battery Replacement, Cover: paso 1, imagen 1 de 3 VTech InnoTab Max Battery Replacement, Cover: paso 1, imagen 2 de 3 VTech InnoTab Max Battery Replacement, Cover: paso 1, imagen 3 de 3
      • Remove all screw caps from the back panel using a metal spudger.
      Pregunta a FixBot
      Agregar Comentario
    2. VTech InnoTab Max Battery Replacement: paso 2, imagen 1 de 3 VTech InnoTab Max Battery Replacement: paso 2, imagen 2 de 3 VTech InnoTab Max Battery Replacement: paso 2, imagen 3 de 3
      • Next remove all of the now uncovered screws.
      • If there is a cartridge in the device make sure to remove it.
      Pregunta a FixBot
      Agregar Comentario
    3. VTech InnoTab Max Battery Replacement: paso 3, imagen 1 de 2 VTech InnoTab Max Battery Replacement: paso 3, imagen 2 de 2
      • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
      Pregunta a FixBot
      Agregar Comentario
    4. VTech InnoTab Max Battery Replacement: paso 4, imagen 1 de 2 VTech InnoTab Max Battery Replacement: paso 4, imagen 2 de 2
      • Here you can see the back cover has been fully removed and you can now access the front cover.
      • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
      Pregunta a FixBot
      Agregar Comentario
    1. VTech InnoTab Max Battery Replacement, Battery: paso 5, imagen 1 de 1
      • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
      Pregunta a FixBot
      Agregar Comentario
    2. VTech InnoTab Max Battery Replacement: paso 6, imagen 1 de 3 VTech InnoTab Max Battery Replacement: paso 6, imagen 2 de 3 VTech InnoTab Max Battery Replacement: paso 6, imagen 3 de 3
      Herramienta utilizada en este paso:
      Plastic Cards
      $2.99
      • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
      • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
      • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
      Pregunta a FixBot
      Agregar Comentario
    3. VTech InnoTab Max Battery Replacement: paso 7, imagen 1 de 3 VTech InnoTab Max Battery Replacement: paso 7, imagen 2 de 3 VTech InnoTab Max Battery Replacement: paso 7, imagen 3 de 3
      • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    4. VTech InnoTab Max Battery Replacement: paso 8, imagen 1 de 1
      • The battery is now fully disconnected.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
8 personas más completaron esta guía.
Equipo
USF Tampa, Team S5-G5, Lacy Spring 2017 Miembro de USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
Miembros de 3
15 Guías creadas
10Guía Comentarios
Thank you for the useful guide!
Which battery (exact specs) can be used as a replacement?
kermit - Contestar Compartir
Where can we purchase a replacement battery
Frank Godon - Contestar Compartir
Where can we buy a replacement battery
Nice of you to show this, but I can not find that particular battery anywhere. Not even the China website.
Let us know where we can get the battery.
Donald Josefczyk - Contestar Compartir
Since it seems like a replacement battery cannot be purchased anywhere, can the battery be bypassed to still use it plugged in? I know it defeats the purpose of a tablet, but it would be nice to still use it. Anyone have suggestions?
ktmm - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 62
Todo El Tiempo: 15,872
