Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
VTech InnoTab 2 Camera Replacement
Qué necesitas
    1. VTech InnoTab 2 Camera Replacement, Battery: paso 1, imagen 1 de 3 VTech InnoTab 2 Camera Replacement, Battery: paso 1, imagen 2 de 3 VTech InnoTab 2 Camera Replacement, Battery: paso 1, imagen 3 de 3
      • Apply slight pressure and slide the button above the battery cabinet to the right to open.
      • Remove battery cabinet cover by sliding away from the center of device.
      • This device requires 4AA batteries to function without the AC adaptor.
      Pregunta a FixBot
      Agregar Comentario
    1. VTech InnoTab 2 Camera Replacement, Back Panel: paso 2, imagen 1 de 3 VTech InnoTab 2 Camera Replacement, Back Panel: paso 2, imagen 2 de 3 VTech InnoTab 2 Camera Replacement, Back Panel: paso 2, imagen 3 de 3
      • Remove all nine plastic caps from the back of the device using the plastic opening tool.
      • These covers are made of hard plastic so they may be difficult to remove.
      Pregunta a FixBot
      Agregar Comentario
    2. VTech InnoTab 2 Camera Replacement: paso 3, imagen 1 de 3 VTech InnoTab 2 Camera Replacement: paso 3, imagen 2 de 3 VTech InnoTab 2 Camera Replacement: paso 3, imagen 3 de 3
      • Remove the hard rubber tab located by the cartridge slot using the plastic opening tool.
      • Be careful not to apply excessive force.
      • Once the rubber tab is removed unscrew the single 7 mm screw using a J0 screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    3. VTech InnoTab 2 Camera Replacement: paso 4, imagen 1 de 2 VTech InnoTab 2 Camera Replacement: paso 4, imagen 2 de 2
      • Remove all ten 7mm screws from the back panel of the device using a JO bit screwdriver.
      • Do not use excessive force while removing the screws to prevent damaging the plastic case.
      Pregunta a FixBot
      Agregar Comentario
    4. VTech InnoTab 2 Camera Replacement: paso 5, imagen 1 de 2 VTech InnoTab 2 Camera Replacement: paso 5, imagen 2 de 2
      • Using the plastic opening tool, detach the back plate from the front piece.
      • Do not use excessive force. If the back plate does not gently come on double check that all screws were removed.
      • Once the back panel is removed, you will be able to see the motherboard and other components within the device.
      Pregunta a FixBot
      Agregar Comentario
    1. VTech InnoTab 2 Camera Replacement, Camera: paso 6, imagen 1 de 3 VTech InnoTab 2 Camera Replacement, Camera: paso 6, imagen 2 de 3 VTech InnoTab 2 Camera Replacement, Camera: paso 6, imagen 3 de 3
      • Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
      • The connection to the camera is located on top side of the devices motherboard.
      • Pulling the camera while the connection to the motherboard is still intact can cause damage to the circuit board.
      • Attach the replacement camera and lower the latch until a click sound can be heard.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Roberto Valdes
Miembro Desde 10/18/17
302 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S1-G85, Cagle Fall 2017 Miembro de USF Tampa, Team S1-G85, Cagle Fall 2017
USFT-CAGLE-F17S1G85
Miembros de 2
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 673
