Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Turtle Beach REACT-R ABXY Buttons Replacement
Qué necesitas
  1. Turtle Beach REACT-R ABXY Buttons Replacement, Rear Case: paso 1, imagen 1 de 3 Turtle Beach REACT-R ABXY Buttons Replacement, Rear Case: paso 1, imagen 2 de 3 Turtle Beach REACT-R ABXY Buttons Replacement, Rear Case: paso 1, imagen 3 de 3
    • Place the controller face down.
    • Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
    • Use both hands to lift the backplate away from the controller.
    Pregunta a FixBot
    Agregar Comentario
  2. Turtle Beach REACT-R ABXY Buttons Replacement, Motherboard: paso 2, imagen 1 de 3 Turtle Beach REACT-R ABXY Buttons Replacement, Motherboard: paso 2, imagen 2 de 3 Turtle Beach REACT-R ABXY Buttons Replacement, Motherboard: paso 2, imagen 3 de 3
    • Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
    • Two of the screws are hidden under the red and black vibration motor wires.
    • Gently lift the motherboard up and out of the chassis.
    • Be careful not to strain the vibration motor wires.
    Pregunta a FixBot
    Agregar Comentario
  3. Turtle Beach REACT-R ABXY Buttons Replacement, ABXY Buttons: paso 3, imagen 1 de 2 Turtle Beach REACT-R ABXY Buttons Replacement, ABXY Buttons: paso 3, imagen 2 de 2
    • With the motherboard removed from the face plate, the buttons will be exposed from the inside.
    • The buttons are no longer secure and may fall out. To avoid this, make sure the controller is face down.
    • Gently remove the ABXY buttons.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 27
Todo El Tiempo: 725
