Introducción
Follow this guide to replace the cutter head on a 2017 Toro Stump Grinder model 22615HD.
You will need a second person to assist with this repair.
Qué necesitas
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Tilt the machine so that it is resting on the handle with the cutter wheel raised.
Use a 14 mm socket to remove the fasteners securing the belt guard:
One 10 mm bolt
One 10 mm nut
Use a 9/16 inch socket to loosen the four nuts securing the bottom of the motor enough to allow the motor to slide freely. Do not remove the nuts.
Use a 1/2 inch wrench in combination with the socket wrench to hold the bolts in place.
Use an impact wrench with a 9/16 inch socket to remove the bolt and washer securing the centrifugal clutch to the spindle.
Use a jaw puller to extract the centrifugal clutch from the spindle:
Place the center screw so that it is in line with the center of the spindle.
Hook the jaws around the back edge of the clutch assembly.
Tighten the center screw until the centrifugal clutch is removed from the spindle.
Paso 16 Remove the pulley
Aviso: los pasos 16-18 provienen de una guía que está marcada como "En progreso".
Use a 1/8 inch hex key to remove the pulley set screw.
Use a 9/16 inch socket to remove the two bolts and washers securing the guard plate to the motor.
Use a 9/16 inch socket to remove the four bolts from the frame.
5 personas más completaron esta guía.
