Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
TomTom Runner GPS Component Replacement
Qué necesitas
  1. TomTom Runner GPS Component Replacement, Wristband: paso 1, imagen 1 de 1
    • First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
    Pregunta a FixBot
    Agregar Comentario
  2. TomTom Runner GPS Component Replacement: paso 2, imagen 1 de 2 TomTom Runner GPS Component Replacement: paso 2, imagen 2 de 2
    • Continue to lift up on the band until the screen of the watch becomes loose from the band.
    • You may need to apply a small amount of force downward on the face of the screen.
    • Continue to pull up on the wristband until it is completely off the watch.
    Pregunta a FixBot
    Agregar Comentario
  3. TomTom Runner GPS Component Replacement, Back Panel: paso 3, imagen 1 de 1
    • Grab the watch once it is separated from the wristband.
    Pregunta a FixBot
    Agregar Comentario
  4. TomTom Runner GPS Component Replacement: paso 4, imagen 1 de 1
    • Flip over the watch and remove the four 3.0 mm Torx head screws with a T4 Torx head screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  5. TomTom Runner GPS Component Replacement: paso 5, imagen 1 de 2 TomTom Runner GPS Component Replacement: paso 5, imagen 2 de 2
    • Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
    • The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
    • Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
    Pregunta a FixBot
    Agregar Comentario
  6. TomTom Runner GPS Component Replacement: paso 6, imagen 1 de 2 TomTom Runner GPS Component Replacement: paso 6, imagen 2 de 2
    • Gently pull the back panel away from the front panel.
    • Do not to pull too fast or too hard. There are red and black wires connected to the vibrator component that should not be ripped.
    Pregunta a FixBot
    Agregar Comentario
  7. TomTom Runner GPS Component Replacement: paso 7, imagen 1 de 2 TomTom Runner GPS Component Replacement: paso 7, imagen 2 de 2
    • Gently wiggle the black box vibrator component away from the back panel with your fingers or a Spudger tool.
    • Be gentle with the red and black wires. You do not want them to rip or pop out.
    • The vibrator component is the small black box with the silver metal part at end. The black box is glued down, so it will take a little force to free it and it will be sticky.
    Pregunta a FixBot
    Agregar Comentario
  8. TomTom Runner GPS Component Replacement, GPS Component: paso 8, imagen 1 de 2 TomTom Runner GPS Component Replacement, GPS Component: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Now lift the smaller square of copper off the front panel. Use the precision tweezers and slide it under the smaller square of copper lining then gently lift it up.
    • You will need to be gentle and pull the copper slowly so that it does not rip.
    Pregunta a FixBot
    Agregar Comentario
  9. TomTom Runner GPS Component Replacement: paso 9, imagen 1 de 3 TomTom Runner GPS Component Replacement: paso 9, imagen 2 de 3 TomTom Runner GPS Component Replacement: paso 9, imagen 3 de 3
    • Use your fingers to gently grab and lift the small square piece to remove the GPS and button component competely from the casing.
    • Disconnect the ZIF Connector from the larger green motherboard.
    • The ZIF Connector is the flat, orange cable connecting the small green motherboard to the larger motherboard. It is meant to come apart at the port located on the larger motherboard. You will feel like you have broken it when it is disconnected. That is okay!
    Pregunta a FixBot
    Agregar Comentario
  10. TomTom Runner GPS Component Replacement: paso 10, imagen 1 de 3 TomTom Runner GPS Component Replacement: paso 10, imagen 2 de 3 TomTom Runner GPS Component Replacement: paso 10, imagen 3 de 3
    • Get the GPS/Button Component by itself and use the Spudger tool to lift the silver cover off the GPS Component. This will expose the GPS Component.
    Pregunta a FixBot
    Agregar Comentario
  11. TomTom Runner GPS Component Replacement: paso 11, imagen 1 de 2 TomTom Runner GPS Component Replacement: paso 11, imagen 2 de 2
    • Once the GPS Component cover is off and the GPS Component is exposed, you are ready to replace it.
    • The GPS Component is the entire square, grey box piece with the green motherboard attached to it.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Equipo
Texas Tech, Team S8-G6, Bennett Spring 2017 Miembro de Texas Tech, Team S8-G6, Bennett Spring 2017
TTU-BENNETT-S17S8G6
Miembros de 4
15 Guías creadas
2Guía Comentarios
Where do i buy the GPS component for replacement?
tolstih.kirill - Contestar Compartir
Hi,
Thanx so much for this guide. Now I’m looking for a new GPS component.Do you know where I can buy that?
Regards, Rein Kooijman (the Netherlands)
Rein Kooijman - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 50
Todo El Tiempo: 2,139
