Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
ThinkPad Edge E31 RAM Replacement
Qué necesitas
  1. ThinkPad Edge E31 RAM  Replacement, Battery: paso 1, imagen 1 de 1
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
    Pregunta a FixBot
    Agregar Comentario
  2. ThinkPad Edge E31 RAM  Replacement: paso 2, imagen 1 de 1
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
    Pregunta a FixBot
    Agregar Comentario
  3. ThinkPad Edge E31 RAM  Replacement, ThinkPad Edge E31 Underside Disassembly: paso 3, imagen 1 de 1
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
    Pregunta a FixBot
    Agregar Comentario
  4. ThinkPad Edge E31 RAM  Replacement, RAM: paso 4, imagen 1 de 1
    • The RAM slots are next to the hard drive to the right of the exposed laptop.
    • There are 2 flexible brackets holding each RAM chip in place is.
    • Push these 2 brackets to the sides. This will allow the chips to pop up to a 30° angle.
    Pregunta a FixBot
    Agregar Comentario
  5. ThinkPad Edge E31 RAM  Replacement: paso 5, imagen 1 de 1
    • Once freed from the brackets, the RAM can now be easily pulled out of its slot.
    Pregunta a FixBot
    Agregar Comentario
  6. ThinkPad Edge E31 RAM  Replacement: paso 6, imagen 1 de 1
    • If your laptop has a second RAM chip in the available slot, repeat the previous 2 steps to remove it.
    • If you are going to be putting 2 RAM chips in your laptop, ensure that they are matching makes and models. This will ensure that you avoid any potential issues that may occur by mixing and matching RAM chips.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Riley
Miembro Desde 03/19/17
601 Reputación
6 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 26
Todo El Tiempo: 578
