Introducción
Follow this guide to use a spark tester to test the ignition system on a 2019 Echo Power Pruner model PPT-2620.
This procedure requires two people.
Qué necesitas
Use a T27 Torx screwdriver to remove the two screws securing the bottom of the muffler cover to the motor.
Connect the spark plug boot to the left terminal of the ignition checker.
Watch for a spark in the spark window while a second person pulls the starter to crank the engine.
Consult the ignition checker instruction manual to troubleshoot the device.
