Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Sony Alpha 6000 Shutter Button Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
    1. Sony Alpha 6000 Shutter Button Replacement, Battery: paso 1, imagen 1 de 1
      • Make sure the camera is turned off by turning the switch to OFF.
      Pregunta a FixBot
      Agregar Comentario
    2. Sony Alpha 6000 Shutter Button Replacement: paso 2, imagen 1 de 1
      • Flip the camera around to access the battery compartment.
      • Slide the battery compartment lock to the left to unlock it.
      Pregunta a FixBot
      Agregar Comentario
    3. Sony Alpha 6000 Shutter Button Replacement: paso 3, imagen 1 de 1
      • Locate the blue latch that holds the battery in.
      Pregunta a FixBot
      Agregar Comentario
    4. Sony Alpha 6000 Shutter Button Replacement: paso 4, imagen 1 de 1
      • Push the latch back to release battery.
      Pregunta a FixBot
      Agregar Comentario
    5. Sony Alpha 6000 Shutter Button Replacement: paso 5, imagen 1 de 1
      • The battery can now be taken out of its compartment.
      Pregunta a FixBot
      Agregar Comentario
    1. Sony Alpha 6000 Shutter Button Replacement, Back Cover: paso 6, imagen 1 de 1
      • Turn the camera upside down and unscrew these two bottom 6 mm screws located on either side of the body by using the J00 head screw.
      Pregunta a FixBot
      Agregar Comentario
    2. Sony Alpha 6000 Shutter Button Replacement: paso 7, imagen 1 de 1
      • Turn the camera sideways.
      • Open the mini HDMI compartment and locate the two 6 mm screw underneath and another to the right of the compartment.
      • Unscrew using the J00 head screw.
      Pregunta a FixBot
      Agregar Comentario
    3. Sony Alpha 6000 Shutter Button Replacement: paso 8, imagen 1 de 1
      • Locate the two 4 mm screws within the battery compartment and unscrew them using the J00 screw head.
      Pregunta a FixBot
      Agregar Comentario
    4. Sony Alpha 6000 Shutter Button Replacement: paso 9, imagen 1 de 1
      • Bend the camera's screen forward to uncover two 3 mm screws below the eyepiece.
      • Locate them and unscrew them.
      Pregunta a FixBot
      Agregar Comentario
    5. Sony Alpha 6000 Shutter Button Replacement: paso 10, imagen 1 de 2 Sony Alpha 6000 Shutter Button Replacement: paso 10, imagen 2 de 2
      • Use a plastic opening tool around the body of the camera to wedge the back cover off. Start from the bottom next to the battery compartment.
      • If necessary, lightly use your hand to pull the the back cover down to completely remove it.
      Pregunta a FixBot
      Agregar Comentario
    1. Sony Alpha 6000 Shutter Button Replacement, Shutter Button: paso 11, imagen 1 de 1
      • Once the back cover is off, locate the flash of the camera and push it forward to open it
      Pregunta a FixBot
      Agregar Comentario
    2. Sony Alpha 6000 Shutter Button Replacement: paso 12, imagen 1 de 1
      • Locate the two 3 mm screws within the flash and unscrew them
      Pregunta a FixBot
      Agregar Comentario
    3. Sony Alpha 6000 Shutter Button Replacement: paso 13, imagen 1 de 1
      • Hold the camera from the bottom and using a spudger, go around the top of the camera and separate the top plastic piece from the main body.
      Pregunta a FixBot
      Agregar Comentario
    4. Sony Alpha 6000 Shutter Button Replacement: paso 14, imagen 1 de 2 Sony Alpha 6000 Shutter Button Replacement: paso 14, imagen 2 de 2
      • Hold the top of the camera away from the body.
      • Carefully turn it over to uncover the bottom of the shutter button.
      Pregunta a FixBot
      Agregar Comentario
    5. Sony Alpha 6000 Shutter Button Replacement: paso 15, imagen 1 de 1
      • Locate the two screws holding the shutter button and unscrew them.
      Pregunta a FixBot
      Agregar Comentario
    6. Sony Alpha 6000 Shutter Button Replacement: paso 16, imagen 1 de 1
      Herramienta utilizada en este paso:
      • Once the screws are out, use a pair of tweezers to pull out the circular metal piece under the shutter button.
      Pregunta a FixBot
      Agregar Comentario
    7. Sony Alpha 6000 Shutter Button Replacement: paso 17, imagen 1 de 1
      • Turn the top plastic piece back over.
      • Now you will be able to completely remove the camera's shutter button.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Now that the shutter button is removed, you will be able to replace it with a new piece. To reassemble your device, follow these instructions in reverse order.
7 personas más completaron esta guía.
Equipo
USF Tampa, Team 4-5, Passmore Fall 2016 Miembro de USF Tampa, Team 4-5, Passmore Fall 2016
USFT-PASSMORE-F16S4G5
Miembros de 3
24 Guías creadas
4Guía Comentarios
Check also https://www.youtube.com/watch?v=y3CCJtD0...
You don't need to remove the back cover (and don't try it because first, you need to remove the top cover...)
Philippe Combronde - Contestar Compartir
Where can i buy a replacement button?
Simon Lundh - Contestar Compartir
You can find the flexible cable with the shutter button on aliexpress:
https://www.aliexpress.com/store/product...
Lac Uster - Contestar Compartir
Thank you!
Arshad kltn - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 45
Ultimos 30 días: 167
Todo El Tiempo: 20,110
