Introducción
The purpose of this guide is to instruct users on how to effectively repair a broken wire, as they commonly become damaged. This guide will cover how to repair stranded wire and solid-core (single strand) wire.
Note: to efficiently complete the following guide, it's crucial to know how to strip wires. The following link can be used as a guide for wire stripping before continuing.
Stripping Wire: Wire Stripping
Qué necesitas
Set your tools down on a clean, non-flammable surface.
Attach a stripped wire end to each of the helping hands clips, facing the ends towards each other.
Unravel all of the wire strands for both the wires, intermesh them, and then twist the strands together.
Place the tip of a soldering iron against the exposed wires. You want to heat the wires hot enough such that they'll readily melt the solder.
Slowly feed solder wire into the heated wire. The wire strands should readily absorb the molten solder.
Feed solder wire along the exposed wire until everything is thinly coated.
Once the molten solder saturates the wire strands, allow the solder joint to cool down and solidify (2-3 minutes).
Slide the heat-shrink over the exposed solder joint so that it completely covers the joint and the surrounding insulation.
Wave a heat source (lighter or heat gun) over the heat-shrink material to activate it. Apply heat until the heat-shrink has shrunk securely around the solder joint.
You have successfully soldered two wires together!
For more soldering tips and guides, click here.
Una persona más ha completado esta guía.
