Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Screen Replacement
Qué necesitas
  1. Screen Replacement, Back Cover: paso 1, imagen 1 de 3 Screen Replacement, Back Cover: paso 1, imagen 2 de 3 Screen Replacement, Back Cover: paso 1, imagen 3 de 3
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
    Pregunta a FixBot
    Agregar Comentario
  2. Screen Replacement: paso 2, imagen 1 de 1
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
    Pregunta a FixBot
    Agregar Comentario
  3. Screen Replacement, Battery: paso 3, imagen 1 de 1
    • Remove masking tape from the battery.
    Pregunta a FixBot
    Agregar Comentario
  4. Screen Replacement: paso 4, imagen 1 de 3 Screen Replacement: paso 4, imagen 2 de 3 Screen Replacement: paso 4, imagen 3 de 3
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
    Pregunta a FixBot
    Agregar Comentario
  5. Screen Replacement: paso 5, imagen 1 de 3 Screen Replacement: paso 5, imagen 2 de 3 Screen Replacement: paso 5, imagen 3 de 3
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. Cómo soldar y desoldar conexiones
    • Use caution when operating the soldering iron.
    Pregunta a FixBot
    Agregar Comentario
  6. Screen Replacement, Motherboard: paso 6, imagen 1 de 3 Screen Replacement, Motherboard: paso 6, imagen 2 de 3 Screen Replacement, Motherboard: paso 6, imagen 3 de 3
    • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
    • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
    Pregunta a FixBot
    Agregar Comentario
  7. Screen Replacement: paso 7, imagen 1 de 1
    • Use the nut driver and J00 bit to remove the three 4 mm screws.
    Pregunta a FixBot
    Agregar Comentario
  8. Screen Replacement: paso 8, imagen 1 de 3 Screen Replacement: paso 8, imagen 2 de 3 Screen Replacement: paso 8, imagen 3 de 3
    • Peel back metal tape that is hiding the auxiliary port wires.
    • Remove tape that is holding the speaker wires in place.
    • Lift up on the motherboard to release it from the tablet.
    Pregunta a FixBot
    Agregar Comentario
  9. Screen Replacement, Screen: paso 9, imagen 1 de 1
    • Use the nut driver and the J0 bit to unscrew the four 4 mm screws
    Pregunta a FixBot
    Agregar Comentario
  10. Screen Replacement: paso 10, imagen 1 de 2 Screen Replacement: paso 10, imagen 2 de 2
    • If your are replacing a broken screen be careful when handling broken glass.
    • Remove the screen from the front cover of the device. At this point there should be no other component holding the screen down.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Baylor, Team 4-1, Williams Fall 2016 Miembro de Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
Miembros de 4
14 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 18
Ultimos 30 días: 77
Todo El Tiempo: 3,568
