Saltar al contenido principal
Samsung Watch Active Screen Replacement
Qué necesitas
  1. Samsung Watch Active Screen Replacement, Turn off the watch: paso 1, imagen 1 de 2 Samsung Watch Active Screen Replacement, Turn off the watch: paso 1, imagen 2 de 2
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Watch Active Screen Replacement, Remove the rear screws: paso 2, imagen 1 de 1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Samsung Watch Active Screen Replacement, Separate the back cover from the housing: paso 3, imagen 1 de 3 Samsung Watch Active Screen Replacement, Separate the back cover from the housing: paso 3, imagen 2 de 3 Samsung Watch Active Screen Replacement, Separate the back cover from the housing: paso 3, imagen 3 de 3
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Samsung Watch Active Screen Replacement, Disconnect the sensor array: paso 4, imagen 1 de 2 Samsung Watch Active Screen Replacement, Disconnect the sensor array: paso 4, imagen 2 de 2
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Watch Active Screen Replacement, Remove the back cover: paso 5, imagen 1 de 1
    • Remove the back cover.
  6. Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: paso 6, imagen 1 de 3 Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: paso 6, imagen 2 de 3 Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: paso 6, imagen 3 de 3
    • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
  7. Samsung Watch Active Screen Replacement, Undo the mic tape: paso 7, imagen 1 de 3 Samsung Watch Active Screen Replacement, Undo the mic tape: paso 7, imagen 2 de 3 Samsung Watch Active Screen Replacement, Undo the mic tape: paso 7, imagen 3 de 3
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
  8. Samsung Watch Active Screen Replacement, Lift the core assembly: paso 8, imagen 1 de 2 Samsung Watch Active Screen Replacement, Lift the core assembly: paso 8, imagen 2 de 2
    • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
  9. Samsung Watch Active Screen Replacement, Remove the core assembly: paso 9, imagen 1 de 3 Samsung Watch Active Screen Replacement, Remove the core assembly: paso 9, imagen 2 de 3 Samsung Watch Active Screen Replacement, Remove the core assembly: paso 9, imagen 3 de 3
    • Lift out and remove the core assembly.
  10. Samsung Watch Active Screen Replacement, Loosen the mic: paso 10, imagen 1 de 2 Samsung Watch Active Screen Replacement, Loosen the mic: paso 10, imagen 2 de 2
    • Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
  11. Samsung Watch Active Screen Replacement, Free the barometric sensor: paso 11, imagen 1 de 2 Samsung Watch Active Screen Replacement, Free the barometric sensor: paso 11, imagen 2 de 2
    • Use a spudger to lift the pressure sensor up and out of its recess in the frame.
  12. Samsung Watch Active Screen Replacement, Remove the mic array: paso 12, imagen 1 de 1
    • Carefully remove the microphone and barometric sensor array from the frame.
  13. Samsung Watch Active Screen Replacement, Loosen the screen adhesive: paso 13, imagen 1 de 1
  14. Samsung Watch Active Screen Replacement, Separate the screen and frame: paso 14, imagen 1 de 3 Samsung Watch Active Screen Replacement, Separate the screen and frame: paso 14, imagen 2 de 3 Samsung Watch Active Screen Replacement, Separate the screen and frame: paso 14, imagen 3 de 3
    • Insert the opening tool under the frame where the sensor array was located.
    • Pry upwards to separate the screen from the frame.
  15. Samsung Watch Active Screen Replacement, Remove the screen: paso 15, imagen 1 de 3 Samsung Watch Active Screen Replacement, Remove the screen: paso 15, imagen 2 de 3 Samsung Watch Active Screen Replacement, Remove the screen: paso 15, imagen 3 de 3
    • Use your fingers to pull the frame off the remaining screen adhesive.
    • Clean any remaining adhesive from the frame using isopropyl alcohol (>90%) before installing the new screen.
Conclusión
Una persona más ha completado esta guía.
Tobias Isakeit
Miembro Desde 03/31/14
118,058 Reputación
189 Guías creadas
Equipo
2 comentarios
What replacement adhesive is needed? I think my screen is ok, but it is falling out and I need to reattach it.
Rosalie E. Morgan - Contestar
Try searching on Ali Express or Wish, etc. I just completed a screen replacement, and the screen I got came with 2 adhesives for it.
Colm O'Sullivan -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 41
Ultimos 30 días: 201
Todo El Tiempo: 2,727
