Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung SPEX SCH-R210 antenna Replacement
Qué necesitas
  1. Samsung SPEX SCH-R210 antenna Replacement, Back Cover: paso 1, imagen 1 de 3 Samsung SPEX SCH-R210 antenna Replacement, Back Cover: paso 1, imagen 2 de 3 Samsung SPEX SCH-R210 antenna Replacement, Back Cover: paso 1, imagen 3 de 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
    Pregunta a FixBot
    Agregar Comentario
  2. Samsung SPEX SCH-R210 antenna Replacement, Battery: paso 2, imagen 1 de 1
    • Locate the access notch at the end of the battery compartment.
    Pregunta a FixBot
    Agregar Comentario
  3. Samsung SPEX SCH-R210 antenna Replacement: paso 3, imagen 1 de 1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
    Pregunta a FixBot
    Agregar Comentario
  4. Samsung SPEX SCH-R210 antenna Replacement, Antenna: paso 4, imagen 1 de 2 Samsung SPEX SCH-R210 antenna Replacement, Antenna: paso 4, imagen 2 de 2
    • After removing the battery, unscrew the 4 3/16" screws on the black plastic cover with the Phillips #00 screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  5. Samsung SPEX SCH-R210 antenna Replacement: paso 5, imagen 1 de 2 Samsung SPEX SCH-R210 antenna Replacement: paso 5, imagen 2 de 2
    • Remove the headphone cover from the left side and the volume cover from the right side of the phone.
    Pregunta a FixBot
    Agregar Comentario
  6. Samsung SPEX SCH-R210 antenna Replacement: paso 6, imagen 1 de 1
    • Remove the black plastic cover from the back of the phone. This may take a little effort to remove.
    Pregunta a FixBot
    Agregar Comentario
  7. Samsung SPEX SCH-R210 antenna Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    • The antenna is located on the opposite side of the black plastic cover. Use the tweezers to remove the antenna.
    Pregunta a FixBot
    Agregar Comentario
  8. Samsung SPEX SCH-R210 antenna Replacement: paso 8, imagen 1 de 1
    • The gray rubber antenna cover will need to come out as well. Use the tweezers to remove the gray cover.
    Pregunta a FixBot
    Agregar Comentario
  9. Samsung SPEX SCH-R210 antenna Replacement: paso 9, imagen 1 de 1
    • Replace with a new antenna.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Susan
Miembro Desde 07/11/13
331 Reputación
3 Guías creadas
Equipo
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Miembro de WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 19
Todo El Tiempo: 539
