Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Galaxy Watch3 Motherboard Replacement
Qué necesitas
    1. Samsung Galaxy Watch3 Motherboard Replacement, Unfasten the back cover screws: paso 1, imagen 1 de 1
      • Before starting repairs, take your watch off the charger and power it down.
      • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
      • Don’t worry about removing the screws, they will stay in place in the back cover.
      Pregunta a FixBot
      Agregar Comentario
    2. Samsung Galaxy Watch3 Motherboard Replacement, Wedge open the back cover: paso 2, imagen 1 de 2 Samsung Galaxy Watch3 Motherboard Replacement, Wedge open the back cover: paso 2, imagen 2 de 2
      • Insert an opening tool between the back cover and the metal housing.
      • Twist the opening tool to create a wider gap.
      • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    3. Samsung Galaxy Watch3 Motherboard Replacement, Disconnect the sensor flex cable: paso 3, imagen 1 de 3 Samsung Galaxy Watch3 Motherboard Replacement, Disconnect the sensor flex cable: paso 3, imagen 2 de 3 Samsung Galaxy Watch3 Motherboard Replacement, Disconnect the sensor flex cable: paso 3, imagen 3 de 3
      • Lay the watch face down.
      • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    4. Samsung Galaxy Watch3 Motherboard Replacement, Remove the back cover: paso 4, imagen 1 de 2 Samsung Galaxy Watch3 Motherboard Replacement, Remove the back cover: paso 4, imagen 2 de 2
      • Remove the back cover.
      • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
      Pregunta a FixBot
      Agregar Comentario
    1. Samsung Galaxy Watch3 Motherboard Replacement, Unplug the three connectors: paso 5, imagen 1 de 3 Samsung Galaxy Watch3 Motherboard Replacement, Unplug the three connectors: paso 5, imagen 2 de 3 Samsung Galaxy Watch3 Motherboard Replacement, Unplug the three connectors: paso 5, imagen 3 de 3
      • Use the flat end of a spudger to disconnect the flex cables of the side buttons, the display and the hall sensor.
      Pregunta a FixBot
      Agregar Comentario
    2. Samsung Galaxy Watch3 Motherboard Replacement, Unfasten the motherboard screw: paso 6, imagen 1 de 1
      • Remove the Phillips #00 screw.
      Pregunta a FixBot
      Agregar Comentario
    3. Samsung Galaxy Watch3 Motherboard Replacement, Remove the motherboard: paso 7, imagen 1 de 2 Samsung Galaxy Watch3 Motherboard Replacement, Remove the motherboard: paso 7, imagen 2 de 2
      Herramienta utilizada en este paso:
      • The motherboard is held in place by two small plastic clips.
      • Use a pair of blunt tweezers to lift the motherboard out from underneath the plastic clips towards the buttons.
      • Remove the motherboard.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
If possible, turn on your device and test your repair before resealing.
2 personas más completaron esta guía.
Tobias Isakeit
Miembro Desde 03/31/14
135,545 Reputación
189 Guías creadas
Equipo
1Guía Comentario
What is the cost of R845 mother board of Samsung watch 3- 45 mm
Jayanta Roy - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 29
Ultimos 30 días: 79
Todo El Tiempo: 3,558
