Saltar al contenido principal
Samsung Galaxy Tab A (2019) Screen Replacement
Qué necesitas
Instrucciones de Vídeo
Conclusión
17 personas más completaron esta guía.
Nick Myers
Miembro Desde 04/15/18
3,754 Reputación
26 Guías creadas
9 comentarios
si on a pas conserver le pcb qu’il enlève de l’écran cassé on peux le racheter ou?
Yacine Chennoufi - Contestar
How do you heat up the screen to loosen the glue? Heat gun? Blow dryer? How do you keep from damaging it from getting too hot? Thanks :)
Justin Shields - Contestar
Use a heat gun it will help that’s what I would do
nicholaswiding -
I tried this with a hairdryer. While there are probably options that work better, it still helped a lot. I am too much of a coward to use a heat gun, as I don't want to fry it, so I used my wifes hair dryer to the point where the tablet was very hot to the touch around the edge of the screen.
Kristian Jarmund -
Best and safest way to heat up a device to remove screen is with a heating mat………. i set mine at 75deg
Alan Sears - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 61
Ultimos 30 días: 290
Todo El Tiempo: 14,547
