Introducción
Use this guide to remove or replace a faulty motherboard.
This guide involves removing the rear glass cover, you will need replacement adhesive to reattach the back cover to the phone.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Heat an iOpener and apply it to a long edge of the S8 for about 2 minutes.
In the following steps you will be cutting through the adhesive around the edge of the rear glass panel.
The adhesive on the rear case is laid out as seen in the first image.
The prying pattern as seen from the outside of the phone is as follows:
Thick portions of adhesive
Thin areas of adhesive
Avoid prying here, to protect the fingerprint sensor.
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Insert a SIM card opening tool into the small hole on the left side of the top edge of the phone.
Press to eject the tray.
Remove the SIM card tray from the phone.
Use the flat end of a spudger to disconnect the battery connector.
Use the flat end of a spudger to disconnect the sensor array connector.
After reapplying adhesive, follow these instructions in reverse order to reassemble your device.
36 personas más completaron esta guía.
11 comentarios
does the size differ between s8 and s8+?
can i use s8+ motherboard for s8?
Hi Ginthozan, unfortunately the S8+ motherboard is not compatible with the S8, and vice versa.
Are all the connections and motherboard layouts the same for Sprint vs AT&T S8?
Hello i can’t charge my phone (both directly and wireless). I still can turn on my phone by charging it directly to the battery. I have replaced my chsrging port flexible but it didn’t works. I think the ic is broken. There’s two PMIC for s8, PM8998 and SM5720, which one that i should change if i can’t charge my phone? Thankyou
After change my LCD and the motherboard the display screen (!)
