Saltar al contenido principal
Samsung Galaxy S7 Headphone Jack Replacement
Qué necesitas
Instrucciones de Vídeo
Conclusión
13 personas más completaron esta guía.
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,450 Guías creadas
2 comentarios
Attention Fixers! If you purchase this replacement headphone jack from iFixit, there’s a chance that yours comes with a black plastic clip that covers the headphone plug socket. You’ll need to remove this plastic clip first before attempting to install your new headphone jack.
Kadan Sharpe - Contestar
Thank you Mr. Degnan for this! I worked. Don’t forget to take your time, try using adhesive remover and alcohol afterwards before putting cover on with new adhesive. Even you are firm but not forceful and go around with the picks several times, it will come off. Use the right screwdriver 00 size and don’t forget to disconnect battery! Test it before putting back in place.
Marco - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 18
Ultimos 30 días: 53
Todo El Tiempo: 29,686
