Introducción
This guide demonstrates how to remove or replace the wireless charging coil in your Galaxy S20 Ultra.
You'll need replacement adhesive in order to complete this repair.
Qué necesitas
Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
Slide the pick back and forth along the bottom edge to slice through the adhesive.
Leave your opening pick in the seam to prevent the adhesive from resealing.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
Apply a heated iOpener to the right edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
Apply a heated iOpener to the top edge of the back cover for two minutes.
Gradually slide the pick from the right edge of the device around the top right corner.
Continue slicing along the top edge to fully separate the back cover adhesive.
Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
If you're using Samsung custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Use a spudger to pry up and disconnect the wireless charging coil connector.
Use a pair of tweezers to gently peel the wireless charging coil away from the device.
Remove the wireless charging coil.
After you've completed the repair, follow this guide to test your repair.
2 comentarios
Hi,
I had my s20 Ultra run over by a vehicle about a year ago and I'm going to purchase some parts from here with these awesome tutorials!
Do I need to have a wireless charge coil for it to function? I'm just looking to use my hopefully repaired s20 ultra as a mini PC by using Samsing Dex because I bought the 512gb model with 16gb ram. I can't let all these good and expensive parts go to waste. The wireless charging isn't important to me for these purposes.
Thank you,
Russell
Hey
The S20 ultras wireless also includes NFC and a coil specifically designed for Samsung official lines of their very own cases, (s view, led)
Other than that if you dont mind having nfc, wireless charging or compatibility of those cases then you are good to go.
