Saltar al contenido principal
Samsung Galaxy Book Pro 360 15" Screen Replacement
Qué necesitas
  1. Samsung Galaxy Book Pro 360 15" Screen Replacement, Access the rubber feet: paso 1, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Access the rubber feet: paso 1, imagen 2 de 2
    • Before you begin, shut down your laptop and unplug it.
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  2. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rubber feet: paso 2, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rubber feet: paso 2, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rubber feet: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Insert an opening pick between the rear case and the rubber foot.
    • Pry up with the pick and dislodge the foot from the rear case.
    • Use tweezers or your fingers to remove the rubber foot.
    • Repeat this process on the remaining rubber feet.
    • There are two types of rubber feet for this laptop. During reassembly, make sure the top feet say "M4" and the bottom feet say "M1".
    • To reinstall a rubber foot, align it over the recess and push down until it's secured.
  3. Samsung Galaxy Book Pro 360 15" Screen Replacement, Unfasten the rear case: paso 3, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Unfasten the rear case: paso 3, imagen 2 de 2
    Magnetic Project Mat
    $19.95
    Comprar
    • Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3313.
  4. Samsung Galaxy Book Pro 360 15" Screen Replacement, Insert an opening pick: paso 4, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Insert an opening pick: paso 4, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Insert an opening pick: paso 4, imagen 3 de 3
    • Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
    • Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
    • This may take significant force and multiple tries.
    • Insert an opening pick into the gap you created.
  5. Samsung Galaxy Book Pro 360 15" Screen Replacement, Release the clips: paso 5, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Release the clips: paso 5, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Release the clips: paso 5, imagen 3 de 3
    • Slide the opening pick along the bottom edge to release the clips securing the rear case.
    • Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
  6. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rear case: paso 6, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rear case: paso 6, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the rear case: paso 6, imagen 3 de 3
    • Lift the rear case up and away from the laptop and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  7. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the battery connector's tape: paso 7, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the battery connector's tape: paso 7, imagen 2 de 2
    Comprar
    • Use tweezers or your fingers to peel up and remove the tape covering the battery connector.
    • Set the tape aside. You'll reuse it during reassembly.
  8. Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the battery: paso 8, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the battery: paso 8, imagen 2 de 2
    • Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
    • Gently pry up and disconnect the battery connector from its socket.
  9. Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the display cable's ZIF connector: paso 9, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the display cable's ZIF connector: paso 9, imagen 2 de 2
    • Use the flat end of a spudger to pry up the locking flap on the right display cable's ZIF connector.
  10. Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the display cable: paso 10, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect the display cable: paso 10, imagen 2 de 2
    Comprar
    • Use tweezers or your fingers to grip the display cable's pull tab and gently pull the cable out of its socket on the motherboard.
  11. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the display cable from its recess: paso 11, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the display cable from its recess: paso 11, imagen 2 de 2
    • Slowly pull the right display cable out of its recess.
    • A small clip secures the cable.
    • During reassembly, make sure that the display cable is secured under its clip.
  12. Samsung Galaxy Book Pro 360 15" Screen Replacement, Disconnect and remove the left display cable: paso 12, imagen 1 de 1
    • Repeat the disconnection and removal procedure on the left display cable.
  13. Samsung Galaxy Book Pro 360 15" Screen Replacement, Open the laptop: paso 13, imagen 1 de 1
    • Open the laptop until it's completely flat and lay it down with the display and keyboard facing down.
    • Before laying the laptop down, make sure you have a clean surface that is clear of items that could damage the display.
  14. Samsung Galaxy Book Pro 360 15" Screen Replacement: paso 14, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Screen Replacement: paso 14, imagen 2 de 2
    • Use a Phillips screwdriver to remove the three 3.6 mm screws securing the right screen hinge.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screen screws with new ones labeled #2749.
    • During reassembly, install the screws from left to right.
  15. Samsung Galaxy Book Pro 360 15" Screen Replacement: paso 15, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Screen Replacement: paso 15, imagen 2 de 2
    • Use a Phillips screwdriver to remove the three 3.6 mm screws securing the left screen hinge.
    • During reassembly, install the screws from right to left.
  16. Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the screen: paso 16, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Screen Replacement, Remove the screen: paso 16, imagen 2 de 2
    • Lift the screen up and away from the laptop and remove it.
  17. Samsung Galaxy Book Pro 360 15" Screen Replacement: paso 17, imagen 1 de 1
    • The screen is now detached from the laptop.
Conclusión
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
3 personas más completaron esta guía.
Spencer Day
Miembro Desde 09/14/22
54,795 Reputación
407 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
17,271 Guías creadas
3 comentarios
This is the display assembly. How do you replace the screen?
Chris Wilson - Contestar
Rob -
Is this compatible with the Galaxy Book3 360 2-in-1 15.6" FHD AMOLED Touch Screen Laptop? Model NP750QFG-KA2US. I can't find a good site to confirm compatibility of parts. (FWIW, I don't care if I lose touchscreen capabilities.)
Bret - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 51
Ultimos 30 días: 296
Todo El Tiempo: 8,982
