Saltar al contenido principal
Samsung Galaxy Book Pro 360 15" Fans Replacement
Qué necesitas
  1. Samsung Galaxy Book Pro 360 15" Fans Replacement, Access the rubber feet: paso 1, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Fans Replacement, Access the rubber feet: paso 1, imagen 2 de 2
    • Before you begin, shut down your laptop and unplug it.
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  2. Samsung Galaxy Book Pro 360 15" Fans Replacement, Remove the rubber feet: paso 2, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Fans Replacement, Remove the rubber feet: paso 2, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Fans Replacement, Remove the rubber feet: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Insert an opening pick between the rear case and the rubber foot.
    • Pry up with the pick and dislodge the foot from the rear case.
    • Use tweezers or your fingers to remove the rubber foot.
    • Repeat this process on the remaining rubber feet.
    • There are two types of rubber feet for this laptop. During reassembly, make sure the top feet say "M4" and the bottom feet say "M1".
    • To reinstall a rubber foot, align it over the recess and push down until it's secured.
  3. Samsung Galaxy Book Pro 360 15" Fans Replacement, Unfasten the rear case: paso 3, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Fans Replacement, Unfasten the rear case: paso 3, imagen 2 de 2
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
  4. Samsung Galaxy Book Pro 360 15" Fans Replacement, Insert an opening pick: paso 4, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Fans Replacement, Insert an opening pick: paso 4, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Fans Replacement, Insert an opening pick: paso 4, imagen 3 de 3
    • Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
    • Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
    • This may take significant force and multiple tries.
    • Insert an opening pick into the gap you created.
  5. Samsung Galaxy Book Pro 360 15" Fans Replacement, Release the clips: paso 5, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Fans Replacement, Release the clips: paso 5, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Fans Replacement, Release the clips: paso 5, imagen 3 de 3
    • Slide the opening pick along the bottom edge to release the clips securing the rear case.
    • Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
  6. Samsung Galaxy Book Pro 360 15" Fans Replacement, Remove the rear case: paso 6, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Fans Replacement, Remove the rear case: paso 6, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Fans Replacement, Remove the rear case: paso 6, imagen 3 de 3
    • Lift the rear case up and away from the laptop and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  7. Samsung Galaxy Book Pro 360 15" Fans Replacement, Remove the battery connector's tape: paso 7, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Fans Replacement, Remove the battery connector's tape: paso 7, imagen 2 de 2
    • Use tweezers or your fingers to peel up and remove the tape covering the battery connector.
    • Set the tape aside. You'll reuse it during reassembly.
  8. Samsung Galaxy Book Pro 360 15" Fans Replacement, Disconnect the battery: paso 8, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Fans Replacement, Disconnect the battery: paso 8, imagen 2 de 2
    • Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
    • Gently pry up and disconnect the battery connector from its socket.
  9. Samsung Galaxy Book Pro 360 15" Fans Replacement, Disconnect the left fan's ZIF connector: paso 9, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Fans Replacement, Disconnect the left fan's ZIF connector: paso 9, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Fans Replacement, Disconnect the left fan's ZIF connector: paso 9, imagen 3 de 3
    • Use the pointed end up a spudger to pry up the locking flap on the left fan cable's ZIF connector.
  10. Samsung Galaxy Book Pro 360 15" Fans Replacement, Disconnect the fan cable: paso 10, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Fans Replacement, Disconnect the fan cable: paso 10, imagen 2 de 2
    • Grip the left fan cable's pull tab with tweezers and gently pull the cable out of its socket.
    • Repeat the disconnection procedure on the right fan cable.
  11. Samsung Galaxy Book Pro 360 15" Fans Replacement, Unfasten the fans: paso 11, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Fans Replacement, Unfasten the fans: paso 11, imagen 2 de 2
    • Use a Phillips screwdriver to remove the six 3.5 mm screws securing the fans.
  12. Samsung Galaxy Book Pro 360 15" Fans Replacement, Remove the fans: paso 12, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Fans Replacement, Remove the fans: paso 12, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Fans Replacement, Remove the fans: paso 12, imagen 3 de 3
    • Lift both fans straight up and remove them.
Conclusión
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Spencer Day
Miembro Desde 09/14/22
95,987 Reputación
662 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,648 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 20
Ultimos 30 días: 88
Todo El Tiempo: 1,363
