Saltar al contenido principal
Samsung Galaxy Book Pro 360 15" Battery Replacement
Qué necesitas
  1. Samsung Galaxy Book Pro 360 15" Battery Replacement, Access the rubber feet: paso 1, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Battery Replacement, Access the rubber feet: paso 1, imagen 2 de 2
    • Before you begin, shut down your laptop and unplug it.
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  2. Samsung Galaxy Book Pro 360 15" Battery Replacement, Remove the rubber feet: paso 2, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Battery Replacement, Remove the rubber feet: paso 2, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Battery Replacement, Remove the rubber feet: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Insert an opening pick between the rear case and the rubber foot.
    • Pry up with the pick and dislodge the foot from the rear case.
    • Use tweezers or your fingers to remove the rubber foot.
    • Repeat this process on the remaining rubber feet.
    • There are two types of rubber feet for this laptop. During reassembly, make sure the top feet say "M4" and the bottom feet say "M1".
    • To reinstall a rubber foot, align it over the recess and push down until it's secured.
  3. Samsung Galaxy Book Pro 360 15" Battery Replacement, Unfasten the rear case: paso 3, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Battery Replacement, Unfasten the rear case: paso 3, imagen 2 de 2
    Magnetic Project Mat
    $19.95
    Comprar
    • Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3313.
  4. Samsung Galaxy Book Pro 360 15" Battery Replacement, Insert an opening pick: paso 4, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Battery Replacement, Insert an opening pick: paso 4, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Battery Replacement, Insert an opening pick: paso 4, imagen 3 de 3
    • Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
    • Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
    • This may take significant force and multiple tries.
    • Insert an opening pick into the gap you created.
  5. Samsung Galaxy Book Pro 360 15" Battery Replacement, Release the clips: paso 5, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Battery Replacement, Release the clips: paso 5, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Battery Replacement, Release the clips: paso 5, imagen 3 de 3
    • Slide the opening pick along the bottom edge to release the clips securing the rear case.
    • Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
  6. Samsung Galaxy Book Pro 360 15" Battery Replacement, Remove the rear case: paso 6, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Battery Replacement, Remove the rear case: paso 6, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Battery Replacement, Remove the rear case: paso 6, imagen 3 de 3
    • Lift the rear case up and away from the laptop and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  7. Samsung Galaxy Book Pro 360 15" Battery Replacement, Remove the battery connector's tape: paso 7, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Battery Replacement, Remove the battery connector's tape: paso 7, imagen 2 de 2
    Comprar
    • Use tweezers or your fingers to peel up and remove the tape covering the battery connector.
    • Set the tape aside. You'll reuse it during reassembly.
  8. Samsung Galaxy Book Pro 360 15" Battery Replacement, Disconnect the battery: paso 8, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Battery Replacement, Disconnect the battery: paso 8, imagen 2 de 2
    • Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
    • Gently pry up and disconnect the battery connector from its socket.
  9. Samsung Galaxy Book Pro 360 15" Battery Replacement, Unfasten the battery: paso 9, imagen 1 de 2 Samsung Galaxy Book Pro 360 15" Battery Replacement, Unfasten the battery: paso 9, imagen 2 de 2
    • Use a Phillips screwdriver to remove the four 4.5 mm screws securing the battery.
    • Take care not to puncture the battery with your screwdriver—a punctured battery may leak dangerous chemicals or cause a fire.
  10. Samsung Galaxy Book Pro 360 15" Battery Replacement, Remove the battery: paso 10, imagen 1 de 3 Samsung Galaxy Book Pro 360 15" Battery Replacement, Remove the battery: paso 10, imagen 2 de 3 Samsung Galaxy Book Pro 360 15" Battery Replacement, Remove the battery: paso 10, imagen 3 de 3
    • Lift the battery straight out of its recess and remove it.
Conclusión
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
4 personas más completaron esta guía.
Spencer Day
Miembro Desde 09/14/22
54,947 Reputación
407 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,299 Guías creadas
4 comentarios
Barbara here. Where can I get a battery for my Galaxy 2 Book? It appears to be irreplacable! I spilled water under my laptop, the battery corroded and I work off plug in only now. Nothing works without daily and frequent 'network reset'
Can you help?
bejohnstone@btinternet.com
Northern Ireland
Barbara Johnstone - Contestar
Hi Barbara! It looks like we're out of stock, but you can enter your email on this site to be notified when it's back in stock. You could also look on eBay or Amazon for the battery. The part number is BA96-07916A and the battery model number is AA-PBMN4VN.
Spencer Day -
Hi i have galaxy book 2 360 13 inch
How can i buy battery for my galaxy book 2 360
Nukesh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 37
Ultimos 30 días: 244
Todo El Tiempo: 6,394
