Introducción
Use this guide to replace the touchpad in your Galaxy Book Pro 15".
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of a thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Qué necesitas
Insert an opening pick between the rubber foot and the rear case.
Pry up with the opening pick to release the clips securing the foot.
Remove the foot.
Repeat this procedure for the three remaining feet.
Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the rear case.
Apply a suction cup to the rear case, as close to the center of the bottom edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear case and the frame.
Insert an opening pick into the gap.
Slide the pick along the bottom edge of the rear case to release its plastic clips.
Repeat this process for the left and right edges, but stop before reaching the top edge.
Pull the top of the rear case away from the frame to separate the adhesive and release the remaining clips.
Remove the rear case.
If you're using a using a genuine Samsung replacement rear case, be sure to peel off any adhesive liners from the rear case before securing the top edge's clips.
If you're reusing your rear case, you can use some pre-cut adhesive to re-adhere the top edge if your existing adhesive is no longer sticky.
Insert a spudger between the frame and the bottom of the battery cable connector.
Pry up and disconnect the battery cable connector.
Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the battery.
Use tweezers, or your fingers, to peel back and remove the yellow tape covering the touchpad's cable connector.
Use a spudger to gently pry up the locking flap on the ZIF connector for the touchpad cable.
Use your fingers, or tweezers, to peel the touchpad cable away from the touchpad and separate its adhesive.
Use a Phillips #00 screwdriver to remove the five 1.7 mm screws securing the touchpad.
Swing the display open slightly, but keep the laptop upside-down.
Tilt the touchpad upwards and away from the frame.
Pull the touchpad towards the top of the laptop to separate it from its recess in the frame.
Remove the touchpad.
Use tweezers to peel off and remove the conductive tape on the touchpad.
To reassemble your device, follow the instructions in reverse order.
