Introducción
Use this guide to replace a cracked or broken screen on your Samsung Galaxy A10.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
You’ll need replacement adhesive to reattach components when reassembling the device.
Qué necesitas
Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
Press firmly to eject the tray.
Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
Remove the three Phillips #00 screws (3 mm length).
Use a spudger to disconnect the battery by prying the connector straight up from its socket.
Use the flat end of a spudger to pry up and disconnect the display flex cable from the motherboard.
Heat an iOpener and apply it on the display for at least two minutes to soften the adhesive underneath.
Place a suction cup on the screen near the bottom edge of the phone.
Pull the suction cup upwards and insert an opening pick in the gap between the display glass and the frame.
Slide the opening pick to the bottom left corner to cut through the bottom adhesive.
Leave the opening pick in in the corner to prevent the adhesive from resealing.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
82 personas más completaron esta guía.
12 comentarios
Usefully website. Thanks ifixit team.
screen replacement for samsung galaxy a10s…or a10 screen is the same size as a10s
Useful service guide for display replacement, best website for repairs !
The Missus dropped her phone and the inevitable happened, this guide was invaluable in helping me fit a new screen, and in under thirty minutes! Extremely grateful for this guide, definitely one of the better ones out there…
gracias por las directiones
