Introducción
The Saeco Magic Cappuccino is a simple portafilter machine. The few components can be repaired well. This usually requires removing the top cover, which is shown here.
Qué necesitas
You can find the model designation SIN017 on the bottom of the machine.
Pull off the steam valve knob. To do this, you must pull hard.
Remove all attachments, i.e. the water tank and the drip tray.
Pull off the Cappucinatore.
Unscrew the two Phillips screws on the back.
Lay the machine on its side. Unscrew the two Phillips screws at the front of the underside.
Lift off the top cover and set it aside.
Do not remove the cover completely. It is connected with many cables. You may be able to disconnect the yellow-green cable from the hot plate, then you have more room to move.
Work through the steps in reverse order to reassemble your device.
Un agradecimiento especial a estos traductores:
100%
¡ shingle nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
