Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
SG 552-1 Commando Spring Replacement
Qué necesitas
  1. SG 552-1 Commando Spring Replacement, Gearbox: paso 1, imagen 1 de 2 SG 552-1 Commando Spring Replacement, Gearbox: paso 1, imagen 2 de 2
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Remove the hand guard.
    Pregunta a FixBot
    Agregar Comentario
  2. SG 552-1 Commando Spring Replacement: paso 2, imagen 1 de 2 SG 552-1 Commando Spring Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun.
    • There should be four total.
    Pregunta a FixBot
    Agregar Comentario
  3. SG 552-1 Commando Spring Replacement: paso 3, imagen 1 de 2 SG 552-1 Commando Spring Replacement: paso 3, imagen 2 de 2
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw that is located directly underneath the cocking lever.
    • Remove the 8mm screw located beside the screw you just removed.
    Pregunta a FixBot
    Agregar Comentario
  4. SG 552-1 Commando Spring Replacement: paso 4, imagen 1 de 2 SG 552-1 Commando Spring Replacement: paso 4, imagen 2 de 2
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
    Pregunta a FixBot
    Agregar Comentario
  5. SG 552-1 Commando Spring Replacement: paso 5, imagen 1 de 3 SG 552-1 Commando Spring Replacement: paso 5, imagen 2 de 3 SG 552-1 Commando Spring Replacement: paso 5, imagen 3 de 3
    • Locate the hand grip.
    • Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip.
    • Slide the cover off.
    Pregunta a FixBot
    Agregar Comentario
  6. SG 552-1 Commando Spring Replacement: paso 6, imagen 1 de 2 SG 552-1 Commando Spring Replacement: paso 6, imagen 2 de 2
    • Pull the motor out of the hand grip.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
    Pregunta a FixBot
    Agregar Comentario
  7. SG 552-1 Commando Spring Replacement: paso 7, imagen 1 de 2 SG 552-1 Commando Spring Replacement: paso 7, imagen 2 de 2
    • Locate the pin holding the folding stock in place.
    • Using an allen wrench or something small, carefully push the pin out.
    Pregunta a FixBot
    Agregar Comentario
  8. SG 552-1 Commando Spring Replacement: paso 8, imagen 1 de 2 SG 552-1 Commando Spring Replacement: paso 8, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox.
    • Remove the cover that was held on by the screw.
    Pregunta a FixBot
    Agregar Comentario
  9. SG 552-1 Commando Spring Replacement: paso 9, imagen 1 de 3 SG 552-1 Commando Spring Replacement: paso 9, imagen 2 de 3 SG 552-1 Commando Spring Replacement: paso 9, imagen 3 de 3
    • Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun.
    • Slide off the piece that was held on by those screws.
    Pregunta a FixBot
    Agregar Comentario
  10. SG 552-1 Commando Spring Replacement: paso 10, imagen 1 de 2 SG 552-1 Commando Spring Replacement: paso 10, imagen 2 de 2
    • Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun.
    • The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
    Pregunta a FixBot
    Agregar Comentario
  11. SG 552-1 Commando Spring Replacement: paso 11, imagen 1 de 2 SG 552-1 Commando Spring Replacement: paso 11, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun.
    • Carefully remove the pieces that were held on by the screws.
    Pregunta a FixBot
    Agregar Comentario
  12. SG 552-1 Commando Spring Replacement: paso 12, imagen 1 de 3 SG 552-1 Commando Spring Replacement: paso 12, imagen 2 de 3 SG 552-1 Commando Spring Replacement: paso 12, imagen 3 de 3
    • Pull apart the cover when pulling the gearbox out.
    • Pull the gearbox out.
    • The gears will fall out when taking the gearbox out. Careful not to lose them.
    Pregunta a FixBot
    Agregar Comentario
  13. SG 552-1 Commando Spring Replacement, Spring: paso 13, imagen 1 de 2 SG 552-1 Commando Spring Replacement, Spring: paso 13, imagen 2 de 2
    • Remove these four 15mm screws.
    • Remove this single 8mm screw.
    • Using a Phillips #0 screwdriver, remove the following screws:
    • Remove this single 3mm screw.
    • Remove this single 14mm screw.
    • Detach the pieces unscrewed from the gearbox.
    Pregunta a FixBot
    Agregar Comentario
  14. SG 552-1 Commando Spring Replacement: paso 14, imagen 1 de 2 SG 552-1 Commando Spring Replacement: paso 14, imagen 2 de 2
    • Remove the piece covering the trigger.
    • Remove the safety piece.
    • Using a Phillips #1 screwdriver, remove the 18mm screw beside the trigger.
    Pregunta a FixBot
    Agregar Comentario
  15. SG 552-1 Commando Spring Replacement: paso 15, imagen 1 de 1
    • Remove the metal piece.
    • Removing this piece will permanently damage the metal piece.
    Pregunta a FixBot
    Agregar Comentario
  16. SG 552-1 Commando Spring Replacement: paso 16, imagen 1 de 3 SG 552-1 Commando Spring Replacement: paso 16, imagen 2 de 3 SG 552-1 Commando Spring Replacement: paso 16, imagen 3 de 3
    • Remove the cover and pull out the spring.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Anika Morris
Miembro Desde 10/05/12
1 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 18-41, Regan Fall 2012 Miembro de Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
Miembros de 6
6 Guías creadas
1Guía Comentario
When i read step 15 it seems impossible to up/downgrade spring without damaging the gun permanently??
Marco den Hartog - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 38
Todo El Tiempo: 2,334
