Saltar al contenido principal
Rotor Riot Face Button Replacement
Qué necesitas
  1. Rotor Riot Face Button Replacement, Remove the iPhone mount: paso 1, imagen 1 de 3 Rotor Riot Face Button Replacement, Remove the iPhone mount: paso 1, imagen 2 de 3 Rotor Riot Face Button Replacement, Remove the iPhone mount: paso 1, imagen 3 de 3
    • Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
    • Remove the iPhone mount.
  2. Rotor Riot Face Button Replacement, Unscrew the back cover: paso 2, imagen 1 de 1
    • Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
    • Don't try to remove the back cover all the way yet! It's still connected to the mainboard.
  3. Rotor Riot Face Button Replacement, Swing open the back cover: paso 3, imagen 1 de 3 Rotor Riot Face Button Replacement, Swing open the back cover: paso 3, imagen 2 de 3 Rotor Riot Face Button Replacement, Swing open the back cover: paso 3, imagen 3 de 3
    • Lift up the back cover of the controller.
    • Lift the back cover to a 45 degree angle and place it next to the controller.
    • Don't strain the interconnect cable during this procedure.
  4. Rotor Riot Face Button Replacement, Disconnect the phone connector cable: paso 4, imagen 1 de 3 Rotor Riot Face Button Replacement, Disconnect the phone connector cable: paso 4, imagen 2 de 3 Rotor Riot Face Button Replacement, Disconnect the phone connector cable: paso 4, imagen 3 de 3
    • Use a spudger to disconnect the phone connector cable from the mainboard.
  5. Rotor Riot Face Button Replacement, Remove the back cover: paso 5, imagen 1 de 1
    • Remove the back cover.
  6. Rotor Riot Face Button Replacement, Remove the shoulder buttons: paso 6, imagen 1 de 2 Rotor Riot Face Button Replacement, Remove the shoulder buttons: paso 6, imagen 2 de 2
    • Remove the shoulder buttons by lifting them out of the case.
  7. Rotor Riot Face Button Replacement, Unscrew the mainboard: paso 7, imagen 1 de 1
    • Use a Phillips screwdriver to remove the four 7.0 mm-long screws securing the mainboard.
  8. Rotor Riot Face Button Replacement, Flip over the mainboard: paso 8, imagen 1 de 3 Rotor Riot Face Button Replacement, Flip over the mainboard: paso 8, imagen 2 de 3 Rotor Riot Face Button Replacement, Flip over the mainboard: paso 8, imagen 3 de 3
    • Flip over the mainboard and place it above the controller housing.
    • Avoid tensioning the trigger button cables during this procedure and don't try to remove the mainboard all the way yet! It is still connected to the controller housing.
  9. Rotor Riot Face Button Replacement, Remove the face buttons: paso 9, imagen 1 de 2 Rotor Riot Face Button Replacement, Remove the face buttons: paso 9, imagen 2 de 2
    • Use a pair of tweezers to remove the face buttons from the housing.
    • The alignment pegs on each button are designed to prevent incorrect installation. Make sure your new buttons fit properly in the controller case.
Conclusión
Adriana Zwink
Miembro Desde 12/18/19
40,063 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
141 Miembros
17,757 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 42
