Introducción
De aftapkraan wordt zwaar belast en is een frequente bron van fouten, bijvoorbeeld als er te veel water in de lekbak terechtkomt. Deze handleiding laat zien hoe deze kan worden herzien.
Het aftapventiel is hetzelfde als bij veel apparaten van Bosch, Siemens en Melitta.
Qué necesitas
Remove all attachments such as water reservoir, coffee compartment lid, trestle drawer. Remove all coffee beans in the storage container.
Unscrew the five Torx T10 screws on the back.
Unscrew the two Torx T10 screws on the front edge of the heat plate.
Lift the front edge of the heat plate and slide it forward a bit to clear the tabs on the back edge.
Put the heat plate back down, but in such a way that you can reach the screws underneath.
Unscrew the two Torx T10 screws located under the heat plate.
Gently lift the upper side a bit and put it back down.
Push the side panel on the water tank back about 2 cm.
Place the side panel next to the machine. Do not remove it completely yet, the cables of the switch are still connected.
Disconnect the flat plugs from the switch. Be sure to note the order of the cables for later reassembly.
Remove the side panel.
Lift the top side slightly.
Press down the locking tab on the plug of the white sensor cable and pull off the black plug towards the front of the machine.
Press the two catches of the counterpart on the sides together and slide it out of the opening towards the back.
Now the top is free and you can remove it.
Reach into the machine from the front and rotate the expansion tank about 60 degrees to the right and pull downwards.
Using needle-nose tweezers, pull out the clip (marked in red) that secures the pressure hose to the exhaust valve (with the round black hat, marked in yellow).
Pull out the pressure hose connector. Watch out for the O-ring, it will either get stuck in the port or in the valve. It should be replaced with a new one.
Use a screwdriver to push back on and remove the spring at the bottom of the drain valve.
Lift out the white driver. Pay attention to the position, so he has to be used again later.
Pull the clip at the top of the valve and take out the pressure hose. Watch out for the O-ring, it gets stuck in the connection or in the valve and should be replaced with a new one.
Slide the white part of the drain valve down about 5mm.
Gently lift out the drainage valve.
Pull the cap of the grey upper valve body. Use pliers, if it is stuck.
There are two gaskets, the flat side pointing outwards.
Plunger and downholder
Piston and spring
Replace the gaskets and reassemble the valve.
Voer de stappen in omgekeerde volgorde uit om het apparaat weer in elkaar te zetten.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
