Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Resetting the Clock
    1. Resetting the Clock, Resetting the Clock: paso 1, imagen 1 de 1
      • Locate the buttons named "SET", "SKIP", "VOLUME -", and "VOLUME +", which are situated on the top portion of the Nextplay NP109CR.
      Pregunta a FixBot
      Agregar Comentario
    2. Resetting the Clock: paso 2, imagen 1 de 2 Resetting the Clock: paso 2, imagen 2 de 2
      • Press the "SET" button, the first button from the left in the row located behind the pink snooze bar, three (3) times until the clock display is flashing.
      Pregunta a FixBot
      Agregar Comentario
    3. Resetting the Clock: paso 3, imagen 1 de 1
      • Press the "SKIP" button with the two triangles next to it pointing to the right to advance the hour.
      Pregunta a FixBot
      Agregar Comentario
    4. Resetting the Clock: paso 4, imagen 1 de 1
      • Press the "SKIP" button with the two triangles pointing to the left to retreat the hour.
      Pregunta a FixBot
      Agregar Comentario
    5. Resetting the Clock: paso 5, imagen 1 de 1
      • Press the "VOLUME +" button to advance the minutes forward.
      Pregunta a FixBot
      Agregar Comentario
    6. Resetting the Clock: paso 6, imagen 1 de 1
      • Press the "VOLUME -" button to decrease the minutes.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Once the desired time has been set, the display will continue flashing for about five (5) seconds. When the clock has stopped flashing the clock has been reset successfully. Setting the clock can be very useful when traveling or when living in an area with frequent power outages.
Jacob Aube
Miembro Desde 09/24/12
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 7-50, Forte Fall 2012 Miembro de Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
Miembros de 5
21 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 1,827
