Introducción
Basic instructions: Removing the upper part of the housing
Qué necesitas
Remove all accessory parts like the water reservoir, the brewing assembly as well as the drip try.
Remove all coffee beans from the bean container
Remove the two T10 Torx screws from the bottom of the rear cover.
Remove the five T10 Torx screws as marked
the back frame consist of 3 pieces. Lift the top part out first, then each one of the side pieces
Lift the bean compartment lid and loosen the Torx T10 screw.
Open the water compartment lid and loosen the Torx T10 screw.
The lid is locked into place several times. Carefully loosen the catches and lift off the lid.
Un agradecimiento especial a estos traductores:
100%
¡ oldturkey03 nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
