Saltar al contenido principal
Reemplazo de la batería del Magic Trackpad
Qué necesitas
  1. Reemplazo de la batería del Magic Trackpad, Baterías: paso 1, imagen 1 de 2 Reemplazo de la batería del Magic Trackpad, Baterías: paso 1, imagen 2 de 2
    • Usa un spudger o una moneda para girar la puerta de la batería.
  2. Reemplazo de la batería del Magic Trackpad: paso 2, imagen 1 de 1
    • Desliza las dos pilas AA.
Conclusión
Para volver a armar tu dispositivo, sigue estas instrucciones en orden inverso.
3 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
en es
100%
¡ Francisco Javier Saiz Esteban nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Ronnie
Miembro Desde 10/22/12
3,495 Reputación
5 Guías creadas
4 comentarios
Hello there, is the Trackpad destroyed by misplacing (wrong polarity) the batteries?
Toto1411 - Contestar
I recently found a Magic Trackpad on a junk pile, to find that the batteries are corroded and won’t come out.
I poured a small amount of isopropyl alcohol in the battery cylider, pried with a thin plastic pick and banged it against a table to get out the first battery, but the second one doesn’t want to move.
Any suggestions for how to get it out without destroying the device? The only thing I can think of would be to crazy-glue a thin rod to the top of the battery, maybe pour in some alcohol, and pull/wiggle the battery until it comes out. I’m afraid that any kind of stronger solvent will cause real damage.
Opinions?
shamino - Contestar
The best solvent for leaked alkaline batteries is… tap water!
michel.firholz -
I had corroded batteries in my Magic Keyboard. Exact same construction. I fashioned a thin blade from an aluminum can. It had enough column strength to slide between the battery and the aluminum battery compartment and with different solvents I was able to free the batteries. Now I have a trackpad that I am trying to recondition but not so easy. IPA and WD40 did not free the batteries this time, about to try dilute vinegar.
Eric Andersen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 29
Ultimos 30 días: 107
Todo El Tiempo: 12,562
