Qué necesitas
Apaga el portátil y colócalo boca abajo sobre una superficie que no raye.
Con un destornillador Torx T5, retire los diez tornillos de 6 mm que sujetan el panel posterior.
Retira los cuatro tornillos de 3 mm que sujetan la ranura de expansión del disco duro con un destornillador Phillips nº 0.
Para volver a montar el dispositivo, sigue estas instrucciones en orden inverso.
Un agradecimiento especial a estos traductores:
100%
¡ Mariana Roca nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Un comentario
I managed to take the case apart once, but when I tried to put back the Torx screws back in, I noticed one wouldn't go more than halfway -- it then turned freely. I'd ordered an SSD thinking that it would be a simple matter to install it, but I found that half the Torx screws wouldn't come out, even using a tiny screwdriver to try to prise them out while turning the Torx wrench. They're seated in brass sleeves -- no way I stripped those out; the sleeves must be glued into the plastic of the case and the glue given out. There now seems to be no way to take the case apart without destroying it completely.
