Introducción
This guide is for replacing the three non-motor wheels and bearings of the RazorX DLX Electric Skateboard. The wheels and bearings make it possible for the skateboard to maneuver correctly. Normal use will break them down over time, which may make it unsafe to use. Make sure to use 83mm replacement wheels to match the size of the motorized wheel. If you want to use new bearings as well, the replacement bearings will have to be 608z. Before you start, make sure the power button is switched to off.
Qué necesitas
Flip the skateboard onto its side.
Use a 13 mm socket wrench to remove the nut that holds the wheel onto the trucks.
Pull the wheel off.
See the first photo for the order of reassembly.
Place one washer onto the trucks first.
Place the wheel with your bearings in place onto the trucks, with the face of the wheel outward.
Place the next washer on the trucks.
Place the nut on the trucks, and tighten using a 13mm socket wrench.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Una persona más ha completado esta guía.
