Introducción
This guide is intended to show you how to replace the Charging Port on a RazorX DLX Electric Skateboard. The charging port allows you to properly charge the battery for the skateboard. Check to make sure there is no debris preventing the charging port from correctly working. Be careful when handling wires and the circuit board. Before you start, make sure the device is powered off.
Qué necesitas
Flip the skateboard upside down.
Use a 4 mm Allen key to remove the 25 mm bolt that secures the cover.
Push the cover forward to slide it off.
Flip the skateboard back over.
Remove the six 22 mm bolts indicated on the top side of the skateboard with a 3 mm Allen key.
While holding the nut from the underside of the skateboard remove the four 32 mm bolts with the 3 mm Allen key.
Separate the trucks and control module from the board.
Remove the 20 mm Phillips #0 screw.
Disconnect the DC connector. The DC connector can be identified as the connector with only two wires.
Disconnect the power button. It is a temporary switch, which can be identified by its 4-wire configuration.
Disconnect the Hall effect sensor. It can be identified by its 6-wire configuration.
Disconnect the charging port.
Remove the retaining nut.
Pull the charging port out of the plastic body.
