Introducción
Use this guide to replace the direction pad on the left side of your Razer Kishi.
Qué necesitas
For the right side, remove the five Y0 screws securing the right side of the controller.
Four 9.2 mm screws
One 7.2 mm screw
If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
Four 9.2 mm screws
One 7.2 mm screw
Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
Slide the opening pick along the right edge to loosen the plastic clips.
Slide the opening pick along the top edge to loosen the remaining plastic clips.
Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
Pull the cable out of the socket.
Use a Phillips #0 screwdriver to remove the two 4.4 mm-long screws securing the trigger board.
Remove the breakout board by lifting it straight up, away from the controller.
Use a Phillips #0 screwdriver to remove the two 7.0 mm-long screws securing the trigger.
Use a Phillips #0 screwdriver to remove the two 5.9 mm-long screws.
Remove the rubber cover that is attached on top of the direction pad.
