Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Razer Kishi Bumper Replacement
Qué necesitas
  1. Razer Kishi Bumper Replacement, Remove the screws: paso 1, imagen 1 de 1
    • The opening process is the same on both sides. For simplicity, this guide shows only the right-side opening process. Unscrew whichever side you wish to open and work on.
    • For the right side, remove the five Y0 screws securing the right side of the controller.
    • Four 9.2 mm screws
    • One 7.2 mm screw
    • If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
    • One 7.2 mm screw
    Pregunta a FixBot
    Agregar Comentario
  2. Razer Kishi Bumper Replacement, Release the bottom edge clips: paso 2, imagen 1 de 3 Razer Kishi Bumper Replacement, Release the bottom edge clips: paso 2, imagen 2 de 3 Razer Kishi Bumper Replacement, Release the bottom edge clips: paso 2, imagen 3 de 3
    • Both cases are held together by plastic clips.
    • Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
    • With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
    Pregunta a FixBot
    Agregar Comentario
  3. Razer Kishi Bumper Replacement, Release the side edge clips: paso 3, imagen 1 de 2 Razer Kishi Bumper Replacement, Release the side edge clips: paso 3, imagen 2 de 2
    • Slide the opening pick along the right edge to loosen the plastic clips.
    Pregunta a FixBot
    Agregar Comentario
  4. Razer Kishi Bumper Replacement, Release the top edge clips: paso 4, imagen 1 de 2 Razer Kishi Bumper Replacement, Release the top edge clips: paso 4, imagen 2 de 2
    • Slide the opening pick along the top edge to loosen the remaining plastic clips.
    • Don't try to remove the top side yet, the case is still connected to the board.
    Pregunta a FixBot
    Agregar Comentario
  5. Razer Kishi Bumper Replacement: paso 5, imagen 1 de 3 Razer Kishi Bumper Replacement: paso 5, imagen 2 de 3 Razer Kishi Bumper Replacement: paso 5, imagen 3 de 3
    • Carefully lift the top side and unfold it to the right, like a book.
    Pregunta a FixBot
    Agregar Comentario
  6. Razer Kishi Bumper Replacement, Disconnect the interconnect cable: paso 6, imagen 1 de 3 Razer Kishi Bumper Replacement, Disconnect the interconnect cable: paso 6, imagen 2 de 3 Razer Kishi Bumper Replacement, Disconnect the interconnect cable: paso 6, imagen 3 de 3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
    • Pull the cable out of the socket.
    Pregunta a FixBot
    Agregar Comentario
  7. Razer Kishi Bumper Replacement, Remove the screws: paso 7, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the two 4.4 mm-long screws securing the trigger board.
    Pregunta a FixBot
    Agregar Comentario
  8. Razer Kishi Bumper Replacement, Remove the breakout board: paso 8, imagen 1 de 3 Razer Kishi Bumper Replacement, Remove the breakout board: paso 8, imagen 2 de 3 Razer Kishi Bumper Replacement, Remove the breakout board: paso 8, imagen 3 de 3
    • The breakout board is plugged in. When removing breakout board, it is important to pull it straight out to avoid bending the connectors.
    • Remove the breakout board by lifting it straight up, away from the controller.
    Pregunta a FixBot
    Agregar Comentario
  9. Razer Kishi Bumper Replacement, Remove the screws: paso 9, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the two 7.0 mm-long screws securing the trigger.
    Pregunta a FixBot
    Agregar Comentario
  10. Razer Kishi Bumper Replacement, Remove the trigger: paso 10, imagen 1 de 2 Razer Kishi Bumper Replacement, Remove the trigger: paso 10, imagen 2 de 2
    • Remove the shoulder trigger.
    Pregunta a FixBot
    Agregar Comentario
  11. Razer Kishi Bumper Replacement, Remove the metal pin: paso 11, imagen 1 de 2 Razer Kishi Bumper Replacement, Remove the metal pin: paso 11, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use a pair of tweezers to remove the metal pin which holds the bumper in its place.
    Pregunta a FixBot
    Agregar Comentario
  12. Razer Kishi Bumper Replacement, Remove the bumper: paso 12, imagen 1 de 2 Razer Kishi Bumper Replacement, Remove the bumper: paso 12, imagen 2 de 2
    • Use your fingers to remove the bumper.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Adriana Zwink
Miembro Desde 12/18/19
67,710 Reputación
167 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 123
28,236 Guías creadas
4Guía Comentarios
I can't remove the left shell of the controller. It seems to be either glued down or won't snap off. I'm worried that I would break the shell or even worse, the motherboard inside. Please help because this has been broken since December of last year and I have the tools to fix it and don't want to spend money to buy a new one.
Punkie Spam - Contestar Compartir
Where did you buy the spare part you want to replace?
ZettoBoi - Contestar Compartir
Saved me! Was able to get the right trigger to reattach with the high res images!
Jose Cantu Jr - Contestar Compartir
Hellooo
Unfortunately the trigger on the right is broken for me.
Can anybody say me where i can buy this spare part?
Thanks ☺️
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 46
Todo El Tiempo: 2,537
