Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Razer DeathAdder V3 Pro Encoder Replacement
Qué necesitas
    1. Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: paso 1, imagen 1 de 3 Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: paso 1, imagen 2 de 3 Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: paso 1, imagen 3 de 3
      • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
      • Remove the three 7 mm screws using a Torx T6 screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    2. Razer DeathAdder V3 Pro Encoder Replacement: paso 2, imagen 1 de 2 Razer DeathAdder V3 Pro Encoder Replacement: paso 2, imagen 2 de 2
      • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
      • Insert a spudger into the seam between the top and bottom shells.
      • Gently work around the edges unclipping the internal latches.
      • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
      • Carefully pull the shells apart to unplug the cable in the front.
      Pregunta a FixBot
      Agregar Comentario
    3. Razer DeathAdder V3 Pro Encoder Replacement: paso 3, imagen 1 de 2 Razer DeathAdder V3 Pro Encoder Replacement: paso 3, imagen 2 de 2
      • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
      Pregunta a FixBot
      Agregar Comentario
    1. Razer DeathAdder V3 Pro Encoder Replacement, Encoder: paso 4, imagen 1 de 1
      • Use a T6 Torx screwdriver to remove the 5mm screws securing the circuit board.
      • Unplug the battery from its connection on the right side.
      • Be careful not to break the two clips that hold the PCB at the front of the mouse.
      Pregunta a FixBot
      Agregar Comentario
    2. Razer DeathAdder V3 Pro Encoder Replacement: paso 5, imagen 1 de 1
      • At the front of the PCB next to the encoder, remove the switch held in place by clips by gently pulling it free.
      Pregunta a FixBot
      Agregar Comentario
    3. Razer DeathAdder V3 Pro Encoder Replacement: paso 6, imagen 1 de 2 Razer DeathAdder V3 Pro Encoder Replacement: paso 6, imagen 2 de 2
      • Wear eye protection.
      • Take care not to damage the PCB or any other components.
      • Use a pair of flush cutters to cut the legs of the encoder.
      • Desolder the legs of the 15 mm encoder on the underside of the PCB.
      • Remove the encoder.
      • Always solder in a well ventilated area.
      • Use a solder sucker to remove any excess solder.
      Pregunta a FixBot
      Agregar Comentario
    4. Razer DeathAdder V3 Pro Encoder Replacement: paso 7, imagen 1 de 1
      • Press the new 15 mm encoder into place
      • If the encoder does not fit properly, clean the old solder more thoroughly.
      • Solder the new 15 mm encoder into place.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Nicholas
Miembro Desde 09/24/25
453 Reputación
4 Guías creadas
Equipo
Texas Tech, Team 2-5, Johansen Fall 2025 Miembro de Texas Tech, Team 2-5, Johansen Fall 2025
TTU-JOHANSEN-F25S2G5
Miembros de 5
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 50
Ultimos 30 días: 237
Todo El Tiempo: 1,510
