Saltar al contenido principal
Razer Blade 15" (2020) Screen Replacement
Qué necesitas
  1. Razer Blade 15" (2020) Screen Replacement, Prepare your laptop for disassembly: paso 1, imagen 1 de 2 Razer Blade 15" (2020) Screen Replacement, Prepare your laptop for disassembly: paso 1, imagen 2 de 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    • Close the lid and flip your laptop over so the back cover faces up.
  2. Razer Blade 15" (2020) Screen Replacement, Unfasten the back cover: paso 2, imagen 1 de 1
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  3. Razer Blade 15" (2020) Screen Replacement, Loosen the back cover: paso 3, imagen 1 de 3 Razer Blade 15" (2020) Screen Replacement, Loosen the back cover: paso 3, imagen 2 de 3 Razer Blade 15" (2020) Screen Replacement, Loosen the back cover: paso 3, imagen 3 de 3
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  4. Razer Blade 15" (2020) Screen Replacement, Remove the back cover: paso 4, imagen 1 de 3 Razer Blade 15" (2020) Screen Replacement, Remove the back cover: paso 4, imagen 2 de 3 Razer Blade 15" (2020) Screen Replacement, Remove the back cover: paso 4, imagen 3 de 3
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
  5. Razer Blade 15" (2020) Screen Replacement, Soften the battery cable tape adhesive: paso 5, imagen 1 de 2 Razer Blade 15" (2020) Screen Replacement, Soften the battery cable tape adhesive: paso 5, imagen 2 de 2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
  6. Razer Blade 15" (2020) Screen Replacement, Remove the battery cable tape: paso 6, imagen 1 de 3 Razer Blade 15" (2020) Screen Replacement, Remove the battery cable tape: paso 6, imagen 2 de 3 Razer Blade 15" (2020) Screen Replacement, Remove the battery cable tape: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
  7. Razer Blade 15" (2020) Screen Replacement, Disconnect the battery: paso 7, imagen 1 de 2 Razer Blade 15" (2020) Screen Replacement, Disconnect the battery: paso 7, imagen 2 de 2
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  8. Razer Blade 15" (2020) Screen Replacement, Label the antenna cables: paso 8, imagen 1 de 2 Razer Blade 15" (2020) Screen Replacement, Label the antenna cables: paso 8, imagen 2 de 2
    • In the next two steps, you'll disconnect the Wi-Fi antenna cables to access other components.
    • The antenna cables look very similar. Label one of them with a piece of tape or marker and remember which socket it connects to.
  9. Razer Blade 15" (2020) Screen Replacement, Disconnect the antenna cables: paso 9, imagen 1 de 3 Razer Blade 15" (2020) Screen Replacement, Disconnect the antenna cables: paso 9, imagen 2 de 3 Razer Blade 15" (2020) Screen Replacement, Disconnect the antenna cables: paso 9, imagen 3 de 3
    $3.99
    • Insert one arm of angled tweezers under the metal neck of each antenna cable and pry up to disconnect it.
    • During reassembly, align the connector over its socket and gently press down with the flat end of your spudger or your fingernail until it clicks into place.
  10. Razer Blade 15" (2020) Screen Replacement, Disconnect the screen press connector: paso 10, imagen 1 de 2 Razer Blade 15" (2020) Screen Replacement, Disconnect the screen press connector: paso 10, imagen 2 de 2
    • Grab the pull tab on the screen connector.
    • Pull up to disconnect the connector from its socket.
    • During reassembly, align the connector over its socket and press down until it clicks into place.
  11. Razer Blade 15" (2020) Screen Replacement, Disconnect the charging port: paso 11, imagen 1 de 3 Razer Blade 15" (2020) Screen Replacement, Disconnect the charging port: paso 11, imagen 2 de 3 Razer Blade 15" (2020) Screen Replacement, Disconnect the charging port: paso 11, imagen 3 de 3
    • Use the point of your spudger to press on alternating sides of the charging port connector to "walk" it out of its socket.
  12. Razer Blade 15" (2020) Screen Replacement, Move the charging cable: paso 12, imagen 1 de 2 Razer Blade 15" (2020) Screen Replacement, Move the charging cable: paso 12, imagen 2 de 2
    • Move the charging cable over the right edge of the laptop.
  13. Razer Blade 15" (2020) Screen Replacement, Unfasten the right hinge cover: paso 13, imagen 1 de 1
    • Use a Phillips screwdriver to remove the three 6.7 mm screws securing the right hinge cover.
  14. Razer Blade 15" (2020) Screen Replacement, Remove the right hinge cover: paso 14, imagen 1 de 2 Razer Blade 15" (2020) Screen Replacement, Remove the right hinge cover: paso 14, imagen 2 de 2
    • Remove the right hinge cover.
  15. Razer Blade 15" (2020) Screen Replacement, Pry up the charging port: paso 15, imagen 1 de 2 Razer Blade 15" (2020) Screen Replacement, Pry up the charging port: paso 15, imagen 2 de 2
    • Hold the charging port cables out of the way of the heatsink.
    • Use the flat end of your spudger to pry up the top screw mount of the charging port until it clears the hinge.
  16. Razer Blade 15" (2020) Screen Replacement, Remove the charging port: paso 16, imagen 1 de 2 Razer Blade 15" (2020) Screen Replacement, Remove the charging port: paso 16, imagen 2 de 2
    • Rotate the charging port counterclockwise and slide the lower screw mount out from underneath the motherboard.
    • Remove the charging port.
  17. Razer Blade 15" (2020) Screen Replacement, Disconnect the left-side screen cable: paso 17, imagen 1 de 2 Razer Blade 15" (2020) Screen Replacement, Disconnect the left-side screen cable: paso 17, imagen 2 de 2
    • Grab the pull tab on the neck of the left-side screen connector and pull it straight out of its socket.
  18. Razer Blade 15" (2020) Screen Replacement, Unclip the screen cable: paso 18, imagen 1 de 3 Razer Blade 15" (2020) Screen Replacement, Unclip the screen cable: paso 18, imagen 2 de 3 Razer Blade 15" (2020) Screen Replacement, Unclip the screen cable: paso 18, imagen 3 de 3
    • Pull the left-side screen cable out from the clips along the left edge of the fan.
  19. Razer Blade 15" (2020) Screen Replacement, Unfasten the left hinge cover: paso 19, imagen 1 de 1
    • Use your Phillips screwdriver to remove the two 6.7 mm screws securing the left hinge cover.
    • Depending on the condition of your screwdrivers, either a Phillips #1 or Phillips #0 will work.
  20. Razer Blade 15" (2020) Screen Replacement, Remove the left hinge cover: paso 20, imagen 1 de 2 Razer Blade 15" (2020) Screen Replacement, Remove the left hinge cover: paso 20, imagen 2 de 2
    • Remove the left hinge cover.
  21. Razer Blade 15" (2020) Screen Replacement, Unclip the right-side screen and antenna cables: paso 21, imagen 1 de 2 Razer Blade 15" (2020) Screen Replacement, Unclip the right-side screen and antenna cables: paso 21, imagen 2 de 2
    • Unclip the right-side screen and antenna cables from the fan and move them over the right side of the laptop.
  22. Razer Blade 15" (2020) Screen Replacement, Prop up your laptop: paso 22, imagen 1 de 1
  23. Razer Blade 15" (2020) Screen Replacement, Unfasten the hinges: paso 23, imagen 1 de 3 Razer Blade 15" (2020) Screen Replacement, Unfasten the hinges: paso 23, imagen 2 de 3 Razer Blade 15" (2020) Screen Replacement, Unfasten the hinges: paso 23, imagen 3 de 3
    • Hold the laptop steady with one hand.
    • Use your Phillips screwdriver to remove the five 4.7 mm screws securing the screen hinges.
  24. Razer Blade 15" (2020) Screen Replacement, Remove the screen: paso 24, imagen 1 de 3 Razer Blade 15" (2020) Screen Replacement, Remove the screen: paso 24, imagen 2 de 3 Razer Blade 15" (2020) Screen Replacement, Remove the screen: paso 24, imagen 3 de 3
    • Hold both halves of the laptop steady during this step, as they might fall unexpectedly.
    • Slide the screen hinges away from the frame to free them from their recesses.
    • Remove the screen.
Conclusión
Clay Eickemeyer
Miembro Desde 09/19/22
81,913 Reputación
455 Guías creadas
Equipo
Guide Team Miembro de Guide Team
Staff
Miembros de 9
11,426 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 45
Todo El Tiempo: 1,168
