Saltar al contenido principal
Razer Blade 15" (2018) SSD Replacement
Qué necesitas
  1. Razer Blade 15" (2018) SSD Replacement, Prepare your laptop for disassembly: paso 1, imagen 1 de 2 Razer Blade 15" (2018) SSD Replacement, Prepare your laptop for disassembly: paso 1, imagen 2 de 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15" (2018) SSD Replacement, Unfasten the back cover: paso 2, imagen 1 de 1
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  3. Razer Blade 15" (2018) SSD Replacement, Insert an opening pick: paso 3, imagen 1 de 3 Razer Blade 15" (2018) SSD Replacement, Insert an opening pick: paso 3, imagen 2 de 3 Razer Blade 15" (2018) SSD Replacement, Insert an opening pick: paso 3, imagen 3 de 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15" (2018) SSD Replacement, Angle the opening pick: paso 4, imagen 1 de 3 Razer Blade 15" (2018) SSD Replacement, Angle the opening pick: paso 4, imagen 2 de 3 Razer Blade 15" (2018) SSD Replacement, Angle the opening pick: paso 4, imagen 3 de 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  5. Razer Blade 15" (2018) SSD Replacement, Free the bottom right corner: paso 5, imagen 1 de 3 Razer Blade 15" (2018) SSD Replacement, Free the bottom right corner: paso 5, imagen 2 de 3 Razer Blade 15" (2018) SSD Replacement, Free the bottom right corner: paso 5, imagen 3 de 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2018) SSD Replacement, Free the front edge: paso 6, imagen 1 de 3 Razer Blade 15" (2018) SSD Replacement, Free the front edge: paso 6, imagen 2 de 3 Razer Blade 15" (2018) SSD Replacement, Free the front edge: paso 6, imagen 3 de 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  7. Razer Blade 15" (2018) SSD Replacement, Remove the back cover: paso 7, imagen 1 de 3 Razer Blade 15" (2018) SSD Replacement, Remove the back cover: paso 7, imagen 2 de 3 Razer Blade 15" (2018) SSD Replacement, Remove the back cover: paso 7, imagen 3 de 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
  8. Razer Blade 15" (2018) SSD Replacement, Soften the battery cable tape adhesive: paso 8, imagen 1 de 2 Razer Blade 15" (2018) SSD Replacement, Soften the battery cable tape adhesive: paso 8, imagen 2 de 2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
  9. Razer Blade 15" (2018) SSD Replacement, Peel up the battery cable tape: paso 9, imagen 1 de 3 Razer Blade 15" (2018) SSD Replacement, Peel up the battery cable tape: paso 9, imagen 2 de 3 Razer Blade 15" (2018) SSD Replacement, Peel up the battery cable tape: paso 9, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
  10. Razer Blade 15" (2018) SSD Replacement, Disconnect the battery: paso 10, imagen 1 de 3 Razer Blade 15" (2018) SSD Replacement, Disconnect the battery: paso 10, imagen 2 de 3 Razer Blade 15" (2018) SSD Replacement, Disconnect the battery: paso 10, imagen 3 de 3
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
  11. Razer Blade 15" (2018) SSD Replacement, Unfasten the SSD: paso 11, imagen 1 de 2 Razer Blade 15" (2018) SSD Replacement, Unfasten the SSD: paso 11, imagen 2 de 2
    • Use a Phillips screwdriver to remove the 3 mm screw securing the SSD.
    • The SSD will pop up slightly.
  12. Razer Blade 15" (2018) SSD Replacement, Remove the SSD: paso 12, imagen 1 de 3 Razer Blade 15" (2018) SSD Replacement, Remove the SSD: paso 12, imagen 2 de 3 Razer Blade 15" (2018) SSD Replacement, Remove the SSD: paso 12, imagen 3 de 3
    • Pull the SSD straight out of its socket and remove it.
Conclusión
Clay Eickemeyer
Miembro Desde 09/19/22
81,269 Reputación
455 Guías creadas
Equipo
Guide Team Miembro de Guide Team
Staff
9 Miembros
11,364 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 44
Todo El Tiempo: 1,553
